The client was unable to change the wording in the English language in the footer, translate options in the contact form from Greek to English, and add a language switch next to the email in the top bar on their WordPress site.
1. We checked the 'Houzez > Footer' settings and found that the 'Template type' and 'Display conditions' were not applied to the English translation. After applying these settings, the English footer appeared correctly on both the English and Greek sites.
2. We switched to using the Elementor PRO footer as recommended by our colleague Bobby. The Greek footer, which was still in draft form, was published, translated, and set with the display condition to 'Entire site'.
3. The Elementor Footer is now correctly displaying on the frontend, and the translation is working perfectly.
This topic contains 8 replies, has 3 voices.
Last updated by Nicolas V. 2 days, 17 hours ago.
Assisted by: Nicolas V..
September 18, 2024 at 3:16 pm #16194303
christosS-7
I am trying to make several adjustments to my WordPress site hidden link using WPML. Specifically, I want to change the wording in the English language in the footer, translate options in the contact form on the homepage from Greek to English, and add a language switch (just the flags) next to the email in the top bar of my page.
1) I haven't been able to change the wording in the English language in the footer. 2) The options in the contact form on the homepage remain in Greek and haven't been translated into English. 3) I haven't managed to add a language switch (just the flags) next to the email in the top bar.
How can I change the wording in the English language in the footer?
How can I translate the options in the contact form on the homepage from Greek to English?
How can I add a language switch (just the flags) next to the email in the top bar of my page?
September 18, 2024 at 5:39 pm #16194894
Bobby
We try to keep each ticket to 1 issue, if possible let's focus on one item in this thread and we can split it into separate ones for the rest of the issues.
#1
"I haven't been able to change the wording in the English language in the footer."
How is the footer created? I can see it's made with Elementor, are you using a template?
If yes, please follow this guide on how to translate Elementor templates.
If the item in the footer is a widget, please follow these steps instead.
#2 issue -> let's focus on this once we resolve this thread (i will split into it's own issue) or you are welcome to open a separate ticket for it as well.
#3
" I haven't managed to add a language switch (just the flags) next to the email in the top bar."
I will provide some quick steps here if we need to further debug we can split into separate issue.
It looks like the header area is a custom area, how is it created?
I recommend reviewing this documentation on how to add a language switcher in custom locations.
September 19, 2024 at 7:43 am #16196375
christosS-7
thanks for your support.
For #1
"I haven't been able to change the wording in the English language in the footer." footer is created via my theme -> Houzez (my theme) -> Header & Footer Builder.
I've tried what you said but still isn't working. Is there any change you can take a look?
For #2 and #3 I haven't tried yet what you said to do.
September 20, 2024 at 12:00 am #16200947
Bobby
Thank you,
Bobby
September 24, 2024 at 12:03 am #16212095
Bobby
When I examine the Footer I can confirm that the template assigned to it has the ID 4379 which is used in both languages.
Review Houzez (my theme) -> Header & Footer Builder and you will notice that the templates are not translatable.
Go to WPML->Settings-> Μετάφραση τύπων αναρτήσεων and set "Header & Footer Builder (fts_builder)" to "Translatable"
I have added translation, however, I can verify that there is no way I can set the different ID per language, which is most likely why that field was set to 'not translatable'
As you are using Elementor pro, is it possible to create an Elementor Pro template for the footer and just copy the content from the existing footer into the one created with Elementor? Elementor PRO + WPML function properly together and respect the translations.
September 27, 2024 at 5:53 pm #16231051
christosS-7
Hello, I've tried what you said but didn't work out. Is there any way to try it by yourself?
September 27, 2024 at 6:34 pm #16231118
Nicolas V.
Bobby won't be available for a few days, so I’ll be handling your ticket in the meantime.
- In "Houzez > Footer," I noticed that the "Template type" and "Display conditions" weren’t applied to the English translation. When I applied them, the English footer appeared on both the English and Greek sites.
- So I followed Bobby’s recommendation, I switched to using the Elementor PRO footer instead.
- You had already created the Greek footer, but it was still in draft form.
- I’ve published, translated it, and set the display condition to "Entire site".
Now the Elementor Footer is correctly displaying on the frontend, and the translation is working perfectly.
September 28, 2024 at 7:04 am #16231620
christosS-7
Thank you it's working properly.
The last part of our issue is that the options of the contact form are still in greek instead of English in English version.
New threads created by Nicolas V. and linked to this one are listed below:
https://wpml.org/forums/topic/split-translation-in-english-different-position-for-flags/
September 30, 2024 at 11:41 am #16235967
Nicolas V.
Glad to hear that it now works.
As the original issue is resolved and since we limit one issue per ticket, I have opened a new ticket for your additional question about forms. Let's continue our conversation on that new ticket: https://wpml.org/forums/topic/split-translation-in-english-different-position-for-flags/
Keeping one issue by forum threat helps to keep the forum clean and organized, it will also help other users with similar problems to find solutions when searching the forum.
Thanks for your understanding.
Nico
This ticket is now closed. If you're a WPML client and need related help, please open a new support ticket.
