Last updated by Christopher Amirian 1 year, 9 months ago.
September 20, 2023 at 12:06 pm #14429977
ekaterinaZ-3
Typing Effect Didi Supreme module compatibility issue
September 20, 2023 at 2:49 pm #14431495
Christopher Amirian
WPML Supporter since 07/2020
I created a clean installation of WordPress that you can access using the link below:
I already installed Divi and WPML there.
Please install Divi Supreme plugin there and create a page and use the Typing module to show the problem so we can report this to the compatibility team.
September 20, 2023 at 5:47 pm #14432775
ekaterinaZ-3
Hi, you also need to install Divi Supreme Typing Effect
September 21, 2023 at 6:43 am #14434781
ekaterinaZ-3
I installed Divi suprime, and used the typing module:
September 21, 2023 at 1:55 pm #14440139
Christopher Amirian
Thank you for the information. I checked and if you search for the text of the typing inside the advanced translation editor you will find the text.
For more information:
https://wpml.org/faq/how-to-translate-urls-shortcodes-and-html-attributes-using-the-advanced-translation-editor/
September 25, 2023 at 7:18 am #14454833
ekaterinaZ-3
Can you please guide me a bit? I don't know where to find advanced translator and the place that you show on the screenshot?
September 26, 2023 at 9:16 am #14465143
Christopher Amirian
I recorded a video showing where to find the advanced translation editor and ask some questions there:
The classic editor does not understand the typing feature and it shows the shortcodes that Divi builder generates only.
So if you do not use the Advanced Translation Editor, then you will need to avoid using Classic editor if you use the typing text and use the manual translation:
Manual translation and the translation editor are separate tools and you can not mix and match them for a page, so if you decide to use a manual mode you will need to start the translation from scratch and stick with it for that page.
September 28, 2023 at 10:41 am #14480641
ekaterinaZ-3
Hi again,
as I'm new with WPML im not sure how I translate. But i dont see, the same things on my site, at you show on the video
October 1, 2023 at 2:04 pm #14493199
Christopher Amirian
I'd appreciate it if you could give me the URL/User/Pass of your WordPress dashboard after you make sure that you have a backup of your website.
The topic ‘[Closed] Typing Effect Didi Supreme module compatibility issue’ is closed to new replies.
