Last updated by Bigul 1 year, 11 months ago.
Assisted by: Bigul.
July 28, 2023 at 7:28 pm #14120097
marinaT-5
I was trying to translate the main menu but I got the following error in the logs
PHP Fatal error: Uncaught Error: Attempt to assign property "front_or_home" on null in /home/mpressprint/public_html/wp-admin/includes/nav-menu.php:379
July 31, 2023 at 6:23 am #14124057
Bigul
WPML Supporter since 01/2013
This may be a compatibility issue with the older version of plugins or theme. So please upgrade to the latest version of plugins and theme(including Avada) after a full site backup{mandatory} and make sure the issue exists or not.
Please refer to the following change log URL of Avada for more details.
Bigul
July 31, 2023 at 1:22 pm #14127799
marinaT-5
The theme is a the latest version, I just updated some plugins but the problem is still present.
July 31, 2023 at 4:23 pm #14128819
Bigul
Thank you for the updates. A couple of requests for tracking this.
1) Please let us know the exact steps to reproduce the issue on your site. Hope you are following the steps described here for translating the Menus - https://wpml.org/documentation/getting-started-guide/translating-menus/#option-2-translating-menus-manually
2) Please fill the private details fields after a full site backup. I would like to access the admin area of your site for further checking. Refer to the following links for more details about our private information sharing policies.
Bigul
August 1, 2023 at 5:06 am #14130317
Bigul
Thank you for the login credentials. I can reproduce the issue on your site. Avada is a compatible theme with WPML. So would like to make sure the issue is existing in a minimal setup(when WPML plugins are only active with the Avada theme).
Do you have a staging/dev site(a clone copy of the live site)? Because it will help us to troubleshoot the issue without affecting the live site.
Please tries the following troubleshooting steps after a full site backup{mandatory} and make sure the issue exists or not.
1) Go to WPML>>Support page, click on the Troubleshooting link (blue link in the middle of the page)
2) On the Troubleshooting page, please click on the following options of the *Clean up* section. Wait for confirmation of processing after each one.
- Clear the cache in WPML
- Fix element_type collation
- Set language information
- Fix WPML tables collation
- Fix terms count
- Fix post type assignment
Bigul
August 1, 2023 at 3:10 pm #14135641
marinaT-5
Thank you, I made a staging site and applied the options you said and the translation menu now works! I'll replicate those on the main site.
