If you're using the WordPress Focal Point plugin to set focal points on images and have noticed that the 'bg_pos_desktop' meta field is not being copied to new translations despite being set to 'Copy', you might be facing a compatibility issue.
First, ensure that you can view the meta field within the media when editing it in the backend. Remember that media IDs differ per language, which might affect the copying process. Unfortunately, the Image Background Focus Position plugin is not officially compatible with WPML. We recommend contacting the plugin author to join our Compatibility program to facilitate compatibility. Meanwhile, you can manually adjust the focal point by:
1. Going to the Media Library.
2. Using the language switcher at the top to switch to the secondary language.
3. Editing the media and adding a focal point manually.
This workaround allows you to set a focal point that could be the same or different per language. For a visual guide on these steps, you can watch this screencast: Workaround steps.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should you need further assistance, please do not hesitate to open a new support ticket at WPML support forum.
Last updated by Bobby 1 year, 4 months ago.
Assisted by: Bobby.
November 15, 2024 at 2:55 pm #16408997
creodeD
I'm using the WordPress Focal Point plugin to set focal points on images within the media library. I have found the specific meta field to use which is called 'bg_pos_desktop'. I went to 'Multilingual Content Setup' -> 'Custom Field Translations' -> 'Searched for bg_pos' and selected 'Copy' for the 'bg_pos_desktop' field. I have selected 'Copy' for this field within my configuration screen. URL: hidden link
The image is duplicated correctly, however, the 'bg_pos_desktop' meta is not added to the new attachment when creating new translations.
Why is the 'bg_pos_desktop' meta not being copied to the new attachment?
How can I ensure that the focal point is duplicated correctly for translated attachments?
November 15, 2024 at 9:56 pm #16409905
Bobby
WPML Supporter since 04/2015
The meta field should be copied if set to 'copy', is there a way you can view the meta field within the media when editing it in the backend that we could use to verify this?
Also, not sure if you are using the media ID to set anything up, but do note that the media have a different ID per language.
The EN media will have a different ID from the same ES media.
November 18, 2024 at 2:17 pm #16415222
creodeD
Hi Bobby,
I agree, the meta field should be copied when you press copy, however this is not happening.
Yes, we can view it in the focal point section at the bottom of the edit pages.
The first screenshot is the original images from my site, with the second being the copied version.
November 18, 2024 at 10:05 pm #16416776
Bobby
I created a sandbox for us to further inspect and can verify that the focal point does not 'copy' over.
The plugin Image Background Focus Position is not an officially compatible plugin with WPML.
I highly suggest reaching out to their author and asking them to join our Compatibility program where we can help them make their plugin compatible with WPML.
https://wpml.org/documentation/support/go-global-program/
In the meantime, you can manually adjust the focal point:
- Go to Media Library
- Use the language switcher at the top and switch to the secondary language
- Edit the media and add a focal point
In this manner, you could technically have a focal point that is either the same per language or different.
Screencast of the workaround steps:
