Last updated by Itamar 9 months, 2 weeks ago.
Assisted by: Itamar.
December 23, 2024 at 1:47 pm #16540621
justinV-10
I am using WPML in a multisite environment and encountering issues with the switch_to_blog() function. My setup includes the latest WordPress version, a multisite installation, and WPML active only on Blog 1. I have a simple plugin that inserts a post after switch_to_blog is called: function wpml_switch_poc_init(): void { $post_arr = [ 'post_title' => 'My very first post', 'post_content' => 'My very first post content', 'post_type' => 'post', ]; $blog_1_post_id = wp_insert_post( $post_arr ); var_dump($blog_1_post_id); switch_to_blog(2); $blog_2_post_id = wp_insert_post( $post_arr ); var_dump($blog_2_post_id); restore_current_blog(); } add_action('plugins_loaded', 'wpml_switch_poc_init'); WPML is not active on Blog 2, and I do not intend to activate it there.
I expected no usage of WPML filters after switch_to_blog is made and WPML is not active in the target blog, with no error messages. Instead, I received a WordPress database error: Table 'db.wp_2_icl_translations' doesn't exist for query SELECT tra.term_taxonomy_id AS translated_id, IFNULL(corr.term_id, 0) AS correct_parent FROM wp_2_term_taxonomy org JOIN wp_2_icl_translations iclo ON org.term_taxonomy_id = iclo.element_id AND iclo.element_type = CONCAT('tax_', org.taxonomy) JOIN wp_2_icl_translations iclt ON iclt.trid = iclo.trid AND iclt.source_language_code = iclo.language_code JOIN wp_2_term_taxonomy tra ON tra.term_taxonomy_id = iclt.element_id LEFT JOIN wp_2_term_taxonomy parents ON parents.term_id = org.parent LEFT JOIN wp_2_icl_translations parent_lang ON parents.term_taxonomy_id = parent_lang.element_id AND parent_lang.element_type = CONCAT('tax_', parents.taxonomy) LEFT JOIN wp_2_icl_translations iclc ON iclc.language_code = iclt.language_code AND parent_lang.trid = iclc.trid LEFT JOIN wp_2_term_taxonomy corr ON corr.term_taxonomy_id = iclc.element_id WHERE org.taxonomy IN ('category') AND IFNULL(corr.term_id, 0) != tra.parent AND iclt.source_language_code IS NOT NULL made by require_once('wp-load.php'), require_once('wp-config.php'), require_once('wp-settings.php'), do_action('plugins_loaded'), WP_Hook->do_action, WP_Hook->apply_filters, wpml_switch_poc_init, wp_insert_post, do_action('save_post'), WP_Hook->do_action, WP_Hook->apply_filters, display_tax_sync_message, do_action('wpml_new_duplicated_terms'), WP_Hook->do_action, WP_Hook->apply_filters, new_duplicated_terms_filter, WPML_Term_Hierarchy_Duplication->duplicates_require_sync, WPML_Term_Hierarchy_Duplication->get_need_sync_all_terms, WPML_Hierarchy_Sync->get_unsynced_elements. WPML filters remain active after using switch_to_blog() despite the plugin not being active on Blog 2.
Why are WPML filters still active after using switch_to_blog() when WPML is not active on Blog 2?
How can I prevent WPML filters from affecting Blog 2?
December 24, 2024 at 10:19 am #16543260
Bruno Kos
I created a multisite here:
And also setup few sites with WPML active.
Logins are:
hello@wpml.org
gE469ajqUY
I will send FTP in the next private reply.
Error logs are activated also.
Can you show us this error here and tell us how can we reproduce it? You can do within this network as you wish. We can check with our 2nd tier then.
December 30, 2024 at 8:14 am #16552310
justinV-10
Hi Bruno,
thanks for your help. I tried replicating my issue but unfortunately your provided setup is already different from my setup:
* WPML is not enabled network wide but only on blog 1.
* WPML is not active on Blog
Since you activated WPML network wide the corresponding tables like "wp_2_icl_translations" exist whereas it doesn't trigger the error message.
I altered your test installation to my plugin activation setup (without my test plugin). If you could remove the icl-tables from blog 2 and blog 3 we could test this issue again and verify the problem.
I've uploaded the testplugin though.
Justin
The topic ‘[Closed] Using WPML in a multisite environment causes several issues using switch_to_blog()’ is closed to new replies.
