You are using WPML to translate your website and have a Divi Module for a Pricing Table saved in the Divi Library, used on multiple pages. However, the majority of the text in the Divi Module is not translating, with only parts like the tabs at the top and the header being translated.
First, ensure you are following the steps outlined in the official Divi documentation for Pricing Tables, which can be found here: https://www.elegantthemes.com/documentation/divi/pricing-tables/.
Next, we recommend trying the workaround suggested in a similar support ticket. Please ensure to take a full site backup before proceeding. You can find the workaround here: https://wpml.org/forums/topic/divi-table-maker-price-table-is-messed-up-on-other-languages-where-can-we-translate-the-entries/#post-16064210.
If this solution does not resolve your issue or seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If you still need assistance, please open a new support ticket at WPML support forum.
Last updated by Bigul 1 week, 3 days ago.
Assisted by: Bigul.
June 18, 2025 at 3:44 pm #17147529
ryanZ-6
I am trying to use WPML to translate our website into other languages. We have a Divi Module for our Pricing table saved in the Divi Library, which we use on multiple pages. This setup allows us to update the pricing table once, and the update reflects on every page it appears. The issue can be seen on this page: hidden link
The link above is to the "Review" page in WPML, its a private page as well, so I'm not sure if it will be able to be opened to view it. Please let me know how I should provide access.
<b>Symptoms: </b>
The Pricing Table text did not fully translate. Only a few parts, like the tabs at the top and the header, were translated, but the majority of the text in the module was not.
<b>Questions: </b>
Why is the majority of the text in the Divi Module not translating?
How can I ensure the entire Pricing Table text is translated using WPML?
June 19, 2025 at 12:03 pm #17150529
Laura
WPML Supporter since 05/2018
thanks for contacting us.
Pricing table isn't a native Divi Module but it comes from one of the addon, therefore you need to register it following this procedure before you can translate it with WPML.
June 26, 2025 at 4:45 pm #17174806
ryanZ-6
Hey Laura,
Thanks for the information.
Do you know of any native Divi Modules that do work with WPML that we could use for our Pricing Module?
Ryan
June 26, 2025 at 8:21 pm #17175237
Bigul
WPML Supporter since 01/2013
Hi Ryan,
Thank you for the updates. We hope you're following the steps outlined in the official Divi documentation:
If so, please try the workaround suggested in the following similar ticket after taking a full site backup, and let us know your feedback.
Bigul
