Last updated by Long Nguyen 1 year, 7 months ago.
Assisted by: Long Nguyen.
November 13, 2023 at 10:28 am #14787297
sellaY
Your editor takes an article with 7-10 text segments (Elementor blocks) and divides it into over 200 segments! The process is slow and extremely difficult. Proofing an article (post) takes 7-8 hours instead of 2-3. It's of no use to me.
For language proofing, I'm using Grammarly, Prowritingaid, and an AI assistant.
I discovered a workaround: auto translate the article and mark it as complete.
Use Elementor to edit the post in the desired language.
Is it okay? Can you recommend a method to speed up proofreading a translation?
November 15, 2023 at 6:45 am #14804451
Long Nguyen
WPML Supporter since 02/2022
Hi Sella,
By default, Advanced Translation Editor breaks your segment (paragraph) into sentences. This allows the editor to keep track of all the translated text in the translation memory across your whole site.
If you want to translate the original segment, you can join the sentences into one. Or consider using the WPML Classic Editor to translate segments on your site.
Please follow the documentation
https://wpml.org/documentation/translating-your-contents/advanced-translation-editor/#translation-memory
https://wpml.org/documentation/translating-your-contents/using-the-translation-editor/
Look forward to your reply.
The topic ‘[Closed] using your editor for translation proofing id SO SLOW’ is closed to new replies.
