This topic contains 9 replies, has 3 voices.
Last updated by sreckoA 1 year, 11 months ago.
Assisted by: Nicolas V..
January 30, 2023 at 10:46 am #12920575
sreckoA
I am trying to:contain original look of my post
Link to a page where the issue can be seen:hidden link
I expected to see:hidden link
Instead, I got:hidden link
January 30, 2023 at 12:49 pm #12921855
before your ticket is assigned to one of my colleagues, please allow me to walk you through some initial debugging steps. This will help speed up the support process.
In order to expedite handling your support requests, can you please share WPML support debug information from your site.
- To give debug information, login to your site and go to WPML → Support. From there click on the “debug information” link at the bottom of the page.
- Once on the “debug information” page, select the entire content of the text box and copy it.
- Now go back to our support forum, find debug information box and paste it.
More information on the link: https://wpml.org/faq/provide-debug-information-faster-support/
January 31, 2023 at 2:17 pm #12930939
sreckoA
debug info
January 31, 2023 at 2:48 pm #12931107
sreckoA
you will see that original serbian site, when translated, completely looses post format, heading goes below featured image...
January 31, 2023 at 9:05 pm #12933365
Nicolas V.
Welcome to the WPML support forum. My name is Nicolas and I will be happy to help you today.
Let's start by meeting WPML's minimum requirements. I've noticed your website has a low PHP memory allocation (40M). The minimum requirements for WPML is 128M but we recommend 256M:
Access your server via FTP and open wp-config.php (in your WordPress root directory).
Insert those lines just before /* That's all, stop editing! Happy blogging. */
/* Memory Limit */
More info: https://wpml.org/home/minimum-requirements/
Now, regarding your issue, it seems that some settings from the original post are not copied in the translation. I can see that the <body> of your translation is missing the class "qodef-blog--info-above-image".
This information is probably coming from a custom field from Qode plugins.
Please try the following:
- Go to "WPML > Settings > Custom fields"
- Check the box " Show "Multilingual Content Setup" meta box on post edit screen." and click "Save"
- Edit the original post, now you should have a list of custom fields used at the bottom of the page
- Click on "Show system fields" to be sure to see all fields
- Do you see any custom field name that could relate to those settings? If so, please change the translation preference to "Copy".
If the issue persist, or you can't find such field, please provide me with a temporary admin access (wp-admin and FTP) – so I can further investigate. I will activate a private field for your next answer where you can provide that information safely (this field is only visible by you and the support team). Don't share your own admin account, create a new one that you will delete when we finish troubleshooting.
IMPORTANT: Before we proceed, please backup your site and database.
Nico
February 1, 2023 at 11:59 am #12937347
Nicolas V.
Thanks for providing me access, unfortunately it seems that the username is not registered on your site:
ERROR: Invalid username. Lost your password?
I will reactivate the private field for your next answer.
February 1, 2023 at 4:18 pm #12940779
Nicolas V.
Thanks for the access.
I have changed the translation preferences to "COPY" for the following fields:
- qodef_blog_single_post_template
- qodef_enable_page_title
- qodef_title_layout
and clicked "Apply"
Then I resaved the original page, and entered the translation to "revalidate" it.
The English post title is now in the same position as the Serbian one but the size is bigger so you might want to do the same with other fields such as:
- qodef_blog_title_italic_words_transform
- qodef_page_title_height
PS: those are the fields with "title" in them, but I would recommend that you contact Qode support to know exactly what is the use of each field. Because there are probably other fields that you need to set as "Copy".
Nico
February 2, 2023 at 1:07 pm #12947619
sreckoA
Nico hi,
Sorry for bothering you again, but you are familiar with my issue, so i chose to ask you for help.
On the post hidden link you will see that the original post has sticky menu, however on english version, sticky menu is not showing. Can you please tell me what to do to make it exact replica.
Tank you in advance,
Srecko
February 2, 2023 at 1:08 pm #12947625
sreckoA
its the same issue so i reopen the ticket
