Last updated by Osama Mersal 1 year, 11 months ago.
Assisted by: Osama Mersal.
September 2, 2023 at 7:04 pm #14330729 | |
bilalB-5 |
Hello team I hope you are doing well. I tried to translate the widget that I attached below, but nothing happened knowing it had been translated at the string translation. hidden link Best regards |
September 3, 2023 at 10:38 am #14331457 | |
Osama Mersal WPML Supporter since 02/2020
Languages: English (English ) Arabic (العربية ) Timezone: Africa/Cairo (GMT+03:00) |
Hi, Thanks for contacting WPML forums support. I'll be glad to help you today. 1) Please try the following steps: 1- Go to WPML-> Theme and plugins localization, select your theme/plugin, and scan Kindly check our guide to know more about translating texts in the admin texts screen. (https://wpml.org/documentation/getting-started-guide/string-translation/finding-strings-that-dont-appear-on-the-string-translation-page/) 2) It's not related to the issue, but according to your Debug.info, the WP memory limit needs to be increased. PHP memory is fine, but WordPress uses 40Mb as default. The minimum requirements for WPML are 128 MB. (Kindly check this page https://wpml.org/home/minimum-requirements/) You can increase it by adding the following code in your wp-config.php file right before the /* That's all, stop editing! Happy publishing. */ line: /* Memory Limit */ define('WP_MEMORY_LIMIT', '256M'); define( 'WP_MAX_MEMORY_LIMIT', '256M'); Best regards, |
September 10, 2023 at 1:18 pm #14371313 | |
bilalB-5 |
Hello Osama I hope you are doing well. The string has been translated, but it does not show up in Arabic. Please, could you take a close look through the dashboard? Best regards |
September 10, 2023 at 1:39 pm #14371371 | |
Hi, Thanks for your update. I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP) Your next answer will be private, which means only you and I can access it. ❌ Please backup your database and website ❌ ✙ I would need your permission to de-activate and re-activate the Plugins and the Theme and change configurations on the site. This is also a reason the backup is critical. ✙ I also need your permission to take a local copy of your site to debug the issue without affecting your live site. Best regards, |
September 13, 2023 at 4:29 pm #14391679 | |
Hi, Thanks for the access details. I checked the issue and was able to fix it by adding the following code to the WPML-> Settings-> Custom XML tab. <wpml-config> <admin-texts> <key name="widget_custom_html"> <key name="*"> <key name="title"/> <key name="content"/> </key> </key> </admin-texts> </wpml-config> Please check our guide about custom XML configurations. (https://wpml.org/documentation/support/language-configuration-files/) Best regards, |
September 13, 2023 at 9:26 pm #14392627 | |
bilalB-5 |
Hello Thank you so much for the help. I can see it works well. Best regards |
September 14, 2023 at 6:47 am #14393541 | |
Hi, It's great to hear that the issue is fixed 🙂 . Please don't hesitate to open a new ticket if you face any other issues. We are always happy to help you. Have a great day! Best regards, |
