Supporter timezone: America/Los_Angeles (GMT-08:00)
Last updated by Bobby 1 year, 11 months ago.
Assisted by: Bobby.
February 6, 2023 at 7:41 pm #12971999
nickS-28
I am trying to:
switch currency and have the correct currency label displayed
staging
I expected to see:
switched currency and have the correct currency label displayed
Instead, I got:
switch currency does not change currency label
as you see in the images, I on purpose changed the € amount to 15 and left the CHF amount at 14 in order to verify that the currency switcher works, The amount reflects the correct version, but as you see, "CHF" stays visible and the currency label has a bug, not displaying the "€" label when switched
February 6, 2023 at 11:29 pm #12972695
Bobby
Timezone: America/Los_Angeles (GMT-08:00)
Are you using a custom theme at the moment?
If possible switch the theme temporarily to a standard WP theme such as twenty23 and let me know your results.
Does the issue persist ?
February 6, 2023 at 11:32 pm #12972701
nickS-28
no custom theme
wp pagebuilder framework
just tried with twenty23, same issue persists
February 7, 2023 at 6:10 pm #12981573
Bobby
Thank you,
Bobby
February 7, 2023 at 11:20 pm #12982685
nickS-28
Please let me know whether you are able to log in
February 9, 2023 at 7:23 am #12994677
Bobby
Thank you, I was able to log in but I am not an admin therefore cannot view the backend to further test.
February 9, 2023 at 9:03 am #12995389
nickS-28
hi, user role has just been adjusted to admin, pls check
February 10, 2023 at 4:30 am #13004059
Bobby
Thank you!
I was able to test this and can confirm the issue remains even with WPML deactivated.
Go to plugins->deactivate WPML and test again,.
In WooCommerce's settings, the Swiss Frank is the default currency, and when WPML is deactivated it remains showing the Euro sign. The same happens even if you change the currency to something else.
Please review if you have some custom code that could affect this or another third-party plugin.
The topic ‘[Closed] wocommerce mult-currency – currency label not changing, though amount changes’ is closed to new replies.
