Last updated by Long Nguyen 1 year, 10 months ago.
Assisted by: Long Nguyen.
June 17, 2023 at 10:51 am #13843605
jamesC-40
Hi.
We have translated the string for Woocommerce points and rewards (see screenshot).
But this is not updated on the front end (see screenshot).
June 19, 2023 at 7:16 am #13847501
Long Nguyen
WPML Supporter since 02/2022
Hi James,
I see that issue on your site. Please try to clear all caches (browser, plugin, hosting, Cloudflare ...) and check this issue again.
If it does not help, I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue. It would be better to a testing site where the issue is replicated. Your next reply is set to private to share the info.
You can use this plugin to create the backup:
https://wordpress.org/plugins/duplicator/
✙ I would need your permission to de-activate and re-activate Plugins and the Theme and to change configurations on the site if needed. This is also a reason the backup is critical.
Look forward to your reply.
June 20, 2023 at 1:55 am #13855093
Long Nguyen
The string
Earn up to <strong>{points}</strong> {points_label}.
is configured on the plugin options page so you should find the text in WPML > String Translation > Translate texts in admin screens. Please check this screenshot hidden link
And read more in the documentation https://wpml.org/documentation/getting-started-guide/string-translation/finding-strings-that-dont-appear-on-the-string-translation-page/#strings-arent-selected-for-translation
The topic ‘[Closed] Woocommerce points and rewards not translating’ is closed to new replies.
