I am facing an issue with translating the header and footer on my website.
The theme I am using has its own built-in header and footer system. However, these elements are not appearing anywhere in WPML translation options — neither in Automatic Translation nor in Manual Translation.
Because of this:
I am unable to translate the header content (menu, labels, etc.)
I am also unable to translate the footer content
These elements are completely missing from WPML’s translation interface
Also, I'd appreciate it if you could give me the URL/User/Pass of your WordPress dashboard after you make sure that you have a backup of your website.
Please also provide the HTTP user pass as the front end can not be checked and a password and username is needed. You can add them under server info.
Note: We will do our best to see if it is possible to translate the header/footer but it might not be possible if the theme is not compatible.
After that, please make sure that you go to WordPress Dashboard > WPML > WP Menu Sync, select all the items and click the sync button and wait for the process to finish.
You now have + icons next to the footer, headers, banners and other stuff that the theme has.
Note: We do not have an official compatibility with the theme you use. It might be some scenarios where the inclusion of the theme developers will be necessary, as we will not be able to delve to their code to see why there is a conflict.
