The client is unable to translate certain items due to an error with HTML breaks affecting the translation process.
We recommend refreshing the editing screen to see if the translation tools become visible and functional. If the issue persists, please update the WPML Multilingual CMS plugin from version 4.6.14 to 4.6.15 and check if the problem is resolved. Additionally, updating all third-party plugins to their latest versions might help resolve the issue. Before making these updates, ensure to back up your entire site (files and database) to prevent any potential data loss.
If these steps do not resolve the issue or if the solution seems outdated or irrelevant to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should the problem persist, please do not hesitate to open a new support ticket for further assistance at WPML support forum.
Last updated by clarissaK-3 1 year, 4 months ago.
Assisted by: Itamar.
December 14, 2024 at 1:47 pm #16513572
clarissaK-3
I want to translate some items using WPML. The issue can be seen on this page: hidden link
There is an error with the HTML breaks, and therefore the items cannot be translated.
Why is there an error with the HTML breaks?
How can I fix the translation issue caused by linebreaks?
December 15, 2024 at 4:47 pm #16515119
Itamar
WPML Supporter since 02/2016
Languages: Hebrew (עברית )
Please give me access to your site and tell me which translation to edit to see this problem.
Privacy and Security Policy
**IMPORTANT**
Itamar.
December 18, 2024 at 8:34 pm #16527648
Itamar
I edited hidden link
I still see the <wpml_linebreak> marker. But I'm able to finish this translation without getting the error.
Is it also working for you?
Itamar.
December 19, 2024 at 12:56 pm #16530292
clarissaK-3
Hei,
yes it is now working for me too. Can you may also try to edit this item: hidden link
Thing is, that sometiems the first time we open a product not all the parts can be properly translated cause it shows errore. But sometimes after reloading the page 2-3 times it then suddenly works.
all the best
Clarissa
December 22, 2024 at 2:51 pm #16537828
Itamar
Hi, Clarissa.
I was able to finish this translation job. I needed to refresh the editing screen of this product to see the pencil icon. Please see the attached screenshot 2024-12-22_16-41-36.jpg.
I've noticed a problem with translation management. I'm unsure if it's related to the problem you described - "sometimes after reloading the page 2-3 times it then suddenly works." The problem is that it is not possible to add a local translator. Please see the attached screenshot 2024-12-22_16-42-03.jpg.
If you want to tackle those problems, please update our plugins to their latest versions and check if they persist.WPML Multilingual CMS 4.6.14 -> 4.6.15. If it persists, update all the third-party plugins to their latest versions and see if it persists.
Itamar.
December 27, 2024 at 1:37 pm #16548588
clarissaK-3
Hey,
thanks for your help. I updated the CMS plugin, so far I can not see any problems. If anything comes up I am gonna contact you again. Thanks for the support.
All the best,
Clarissa
