This topic contains 73 replies, has 0 voices.
Last updated by Shekhar Bhandari 3 weeks, 5 days ago.
February 3, 2026 at 5:47 am
nas-luxuryR
Images imported via WP All Import appear correctly on the English site but are missing on Arabic translations created by WPML, showing the theme placeholder image instead. WPML is not duplicating or syncing media attachments (featured image & gallery) to translated posts. We need help configuring WPML Media Translation so imported images correctly appear in all languages.
February 3, 2026 at 9:22 am #17786357
nas-luxuryR
Hi I need further assistance.
February 3, 2026 at 9:58 am #17786653
nas-luxuryR
Hi, Are you there?
February 3, 2026 at 10:00 am #17786658
Shekhar Bhandari
WPML Supporter since 03/2015
Hello there,
Is the process completed to duplicate the medias? Can you update the product after the process completion and see if it helps?
Look forward to your reply.
February 3, 2026 at 10:50 am #17787053
nas-luxuryR
The process still loading, before i got parse error while running the process. so again i restarted. And now showing Duplicating content: 210550 left. Can you please help me to solve this issue immediately.
February 3, 2026 at 11:02 am #17787068
Shekhar Bhandari
Hello there,
I bulk updated the properties in English and the images are showing now, can you please check, if the problem still exists I suggest you to update the properties in English once.
https://woocommerce.com/posts/bulk-update-products/
February 3, 2026 at 11:19 am #17787125
nas-luxuryR
Hi, You there?
I think that reflects in website. some images are getting now. Remaining is not getting becuase of the process is still running? But i dont think that will finish by one day. Is there any other way ? And next day wp all import automatically imports. So is there anything to change or can i put the same(automatic media translation off).
February 3, 2026 at 11:48 am #17787293
nas-luxuryR
Thanks. I have bulk uploaded the properties. Now images are loading. It will automatically get upcoming days, right? And one more thing is there anything to change or can i put the same(automatic media translation off)?
February 4, 2026 at 4:58 am #17789913
nas-luxuryR
Hi, Good morning!
February 4, 2026 at 5:20 am #17789916
Shekhar Bhandari
Hello there,
Once the media files are duplicated the images should appear without the need of update, I would suggest you to keep the settings as it is due to import workflow you are using.
Let me know if this helps.
February 4, 2026 at 6:00 am #17789925
nas-luxuryR
Hello, Thanks for replying!
Today we have faced the issue for importing. so we manually imported again, then for english site all coming perfectly. But other languages have same problem, missing the some of images.
can you please help me to solve asap. thanks
February 4, 2026 at 6:08 am #17789926
Shekhar Bhandari
Hello there,
From what I see you are importing media files from a different site, so when it's imported the media files translations aren't present.
So we have two options to fix this issue:
- Import the media before importing the properties
- Update the products in bulk after importing.
Did you tried to update the imported products in bulk today and see if it helps?
February 4, 2026 at 6:36 am #17789998
nas-luxuryR
I have bulk updated the products today, but some images are also missing and i searched that in properties list, but it doesn't see. hidden link
Also since we are paying to this, update the products in bulk after importing is not practical everyday. so please help to solve this issue.
February 4, 2026 at 6:44 am #17790001
Shekhar Bhandari
Hello there,
I would like to understand more about how you are importing the content.
I see you are using Bitrix xml feed hidden link but I don't see any translations here, are you only updating the English properties? or is it creating a new properties everyday?
Can you provide your complete workflow so I can debug this further?
February 4, 2026 at 7:05 am #17790011
nas-luxuryR
Yes, we are using a Bitrix XML feed to add property listings via WP All Import. Automatic daily updates are enabled, so any new properties added in Bitrix are imported automatically, and any properties removed from Bitrix are also removed from the website.
We are importing the listings in English, and once a property is added, the WPML auto-translation is applied automatically.
thanks
