Last updated by nickS-28 1 year, 10 months ago.
Assisted by: Osama Mersal.
March 7, 2023 at 10:34 am #13188145
nickS-28
WPML seems to insert wrong terminology into a field in the backend. I do not insert anything manually and have adjusted it a couple of time, but it always comes back. I cannot reproduce it or give any guidance on it, I just suddently after some time see that it has been adjusted again. Maybe the translation database has a translation, it inserts it automatically, causing a German term to be shown on an English page.
March 8, 2023 at 7:38 am #13195809
Osama Mersal
Could you please use the following steps to search for this string?
1- Go to WPML-> Theme and plugins localization, select your theme/plugin, and scan
2- Go to WPML-> String Translation
3- Scroll down and click on the "Translate texts in admin screens »" link
4- Search for the needed strings
5- Select the strings
6- Click on the "Add to String Translation" button
7- Then click on "the « Return to String Translation" link
8- Translate the strings, clear the cache, and check the front end
Kindly check our guide to know more about translating texts in the admin texts screen. (https://wpml.org/documentation/getting-started-guide/string-translation/finding-strings-that-dont-appear-on-the-string-translation-page/)
After finding and translating this string via String Translation, please check if it will work correctly on the front end.
Osama
