Last updated by Waqas Bin Hasan 1 year, 10 months ago.
Assisted by: Waqas Bin Hasan.
August 7, 2023 at 10:02 pm #14166247 | |
quentinO |
Dear team, It looks like the custom route created does not work properly, it looks like a cache problem because it does work sometimes. The data fetched by the API shows perlmalink in the wrong language. I dont have this problem for me others custom post but only when using the API Link to a page where the issue can be seen: hidden link and hidden link for your information in my route i;m using the if ( defined( 'ICL_SITEPRESS_VERSION' ) ) { i debugged and found nothing and i logged the $lang that i recieve as a parameter from the fetch and this $lang is correct (en or pt) i can reproduce this error locally with a generatepress theme and no other pluggins than wpml and no cache, Really need your help im stuck on that Thank you |
August 7, 2023 at 10:15 pm #14166253 | |
quentinO |
Ive noticed that it depends on the language selected by the user, it will fetch the permalink only in the selected language of the user. When i reset the user language it works again but once the user will switch language it starts mixing. For exemple i set the language to PT then he logs in and switch to EN by error but then comes back to a EN page in this case he cannot come back to PT and well only see EN content even though he is on a PT page. Best |
August 8, 2023 at 12:28 pm #14169223 | |
Waqas Bin Hasan WPML Supporter since 05/2014
Hello Quentin, Thank you for contacting the support. I just checked the URL you mentioned in your first message and could see it working fine. I used language switcher to switch between EN and PT, see the screencast hidden link. However, can you please explain in more details that how you are creating custom routes and how you are using the API? Please note that custom coding is out of scope of this forum but I can only review and see if I can help in this matter. Regards. |
August 8, 2023 at 2:07 pm #14169797 | |
quentinO |
Hi Waqas; Yes it's working well on all site but not when i use it with the API. Like for this : hidden link where my custom post does not fetch the good language properly. It's custom code but i want to use a standard features that your are selling (With WPML, you can translate custom post types, custom fields...) Thank you, |
August 9, 2023 at 9:10 am #14174035 | |
Thank you for the updates. WPML offers filters and action hooks that can be used in your WordPress theme or plugin to provide correct multilingual support. Browse following resources for more information: - https://wpml.org/documentation/support/wpml-coding-api/ If you need additional custom work, we recommend you contact WPML Contractors at https://wpml.org/contractors/. |
