I translated an entire article using the String Translation section in WPML. Afterward, I enabled auto-translate credits.
The auto-translate feature overwrote all my manual translations with DeepL translations, which are completely different.
Why does enabling auto-translate overwrite existing translations in the String Translation section?
How do I prevent auto-translate from overwriting my manual translations in the future?
Also is there any way I can disable auto-translate for all strings and within the string area have a button where I can choose to either auto-translate or manually translate?
When a complete article is translated in the string translation area, how do I get this to register in the main article that the translation is complete also?
I'm really not happy with this overwriting issue, I spent 2 hours of my day doing these translations only to have them wiped with completely different and nowhere near as accurate copies. 1/4 of my work day is wasted.
First, you should not use String translation to translate content, it is only to be used for translating strings coming from theme/plugin files and theme/plugin settings. If you use it, your translation will be overwritten each time you update your page.
For translating pages/post and etc, you should use WPML editor or automatic translation. To choose and switch mode you can do that from WPML > Settings.
Then send the pages for translation from WPMl > Translation Managment. From there you can choose to translate yourself via WPML Editor or automatically translate.
