The client was experiencing issues with translating a WooCommerce composite product into Italian using WPML. The translation process was not functioning correctly, sometimes affecting the default English product as well. Specifically, when scenarios were added to composite products, the component dropdown options were not displaying correctly in the Italian version, though they worked fine in English.
We advised the client to ensure that all plugins were up to date and to use the Advanced Translation Editor (ATE) for translating products. It was important to translate using ATE rather than the WordPress Editor to avoid issues with saving changes and to ensure the translation process was handled correctly by WPML. We also suggested translating the products step-by-step using ATE and checking if the issue persisted. If problems continued, we recommended deactivating the WPML plugins temporarily to verify if the issue was indeed related to WPML or if it was an issue with the WooCommerce Composite Products plugin.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket here.
Last updated by Carlos Rojas 8 months, 1 week ago.
Assisted by: Carlos Rojas.
December 31, 2024 at 5:22 am #16554930
marioG-45
I am developing a site and have created a composite product. I am trying to translate this product into Italian using WPML, but it is not translating properly. Sometimes, it also affects the default English product. I have added composite product components and selection scenarios, which seem to cause issues.
When I add scenarios to composite products, the component dropdown options are messed up. The English version works fine, but the Italian version does not.
Why does adding scenarios to composite products affect the dropdown options?
How can I ensure the Italian translation does not break the English product?
December 31, 2024 at 12:08 pm #16555699
Osama Mersal
WPML Supporter since 02/2020
1) Please log in to this hidden link">sandbox site and try to replicate the issue.
If the issue is replicable, please let me know how to reproduce it so I can check it and consult our 2nd tier support team.
Osama
January 2, 2025 at 9:06 pm #16560031
marioG-45
See attached the debug information. Waiting for your kind feedback.
Many thanks,
Mario Garsi
January 2, 2025 at 11:10 pm #16560087
Osama Mersal
Hi Mario,
Thanks for the debug info. Please let me know if you were able to replicate the issue on the sandbox site.
Osama
January 3, 2025 at 11:47 am #16561261
marioG-45
What is your feedback from the debug provided to you?
The issue is still there in sandbox.
You can also see it in staging environment:
[Access Details Removed]
Connect, see it and provide feedback how you can fix the bug you have.
Waiting for your kind and prompt feedback.
Many thanks,
Kind Regards,
Mario Garsi
January 4, 2025 at 7:55 pm #16563795
Osama Mersal
Hi Mario.
1) I removed the site's access details for your site's safety. Please don't share access details unless you see the private reply.
2) I checked the sandbox site but didn't see any added products. Please log in to the sandbox site and try to replicate the issue. (hidden link)
3) The debug info shows that the installation is good. I didn't spot issues there.
Osama
January 6, 2025 at 4:51 am #16565051
marioG-45
Yes Let me check your shared sandbox site and get back to you.
January 6, 2025 at 5:33 am #16565083
marioG-45
Hello WPML support team,
As I checked your sandbox site, I checked you guys just setup the woocommerce and WPML plugin.
But I got the issues in woocommerce composite product while translating it.
I had contact woocommerce support team and they checked all the stuff related to woocommerce and woocommerce composite product. Its working fine.
But when I translating the product in other language I'm getting the issues.
So that's why I created the staging site and shared with you.
So could you please refer my staging site which I shared with you and directly check the issue there ?
January 6, 2025 at 9:22 am #16565431
Osama Mersal
Thanks for your reply. I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
Osama
January 6, 2025 at 11:59 am #16566249
Osama Mersal
Thanks for the access details. I tried to reproduce the issue with the steps you did in the video but couldn't. (Kindly check the attached screenshot)
I used the test product. (hidden link)
Kindly let me know if I missed any steps.
In your video, the issue happens in the default language, so please deactivate WPML plugins and check the product when you reproduce the issue.
Osama
January 7, 2025 at 8:55 am #16568554
marioG-45
I checked test product which you created in the site. But could you please translate that product and check both language product is working fine or not with all the scenarios and component?
I faced that issue when I translate the product in other language.
Sometime that issue occur in default language and sometime its appear in translated language.
So could you please review it and let me know?
January 7, 2025 at 9:26 am #16568617
Osama Mersal
I copied the components to the translated language, and it seems to work correctly. (Kindly check the attached screenshot)
Kindly let me know if I missed any steps in reproducing the issue.
Osama
January 7, 2025 at 9:42 am #16568692
marioG-45
I'm sharing one video link please check it.
In that scenarios are working in English language but not working in Italian.
Video link :- hidden link
Also sometime I'm not getting the options in the Italian language for scenarios selection.
- hidden link
January 7, 2025 at 10:30 am #16568955
marioG-45
Dear Osama,
Is the video link understandable for you. Can you see the different behavior when Scenarios are active within English (original language) and Italian (WPML translated language)?
Looking forward to hearing news soon from you.
many thanks,
Mario
January 7, 2025 at 10:30 am #16568956
Osama Mersal
Please check if the scenarios work correctly in the translated product. (hidden link)
Osama
