The admin string shows as Registered and locked, how can we enable it's translation?
“Registered and locked” means that the string is already registered by the theme or via an XML configuration file. They should appear on the WPML >> String Translation page so that you can translate them.
Last updated by batuhanA-4 3 years, 3 months ago.
Assisted by: Noman.
January 9, 2022 at 1:44 pm #10313287
batuhanA-4
hi there,
i already used before houzez in other projects. I was successfully managed the strings from admin string translations. But in my new project, i can not add and translate some strings because of it doenst let me to add string transtion from Admin Texts Translations. It says "
Registered and locked"
i sent you also picture about the problem. How can i solve this problem? Thanks
January 9, 2022 at 2:20 pm #10313353
Noman
Thank you for contacting WPML Support. “Registered and locked” means that the string is already registered by the theme or via an XML configuration file. They should appear on the WPML >> String Translation page so that you can translate them.
Can you please go to WPML >> String Translation page and search for your required string and see if you find the string?
Thank you
January 9, 2022 at 2:54 pm #10313389
batuhanA-4
Thanks for reply. When i searched with exact match option. system found my string which i find. Thanks its solved.
