You are working on a site under development and trying to add an extra field using
wcml_custom_prices_fields
. The field appears properly, but after saving, its value does not appear.
We recommend adjusting your code as follows:
add_filter( 'wcml_custom_prices_fields', 'add_custom_price_fields', 10, 2 );<br />function add_custom_price_fields( $fields, $product_id ) {<br />// Add a new custom price field<br />$fields[] = '_purchase_cost';<br />return $fields;<br />}<br /><br />add_filter( 'wcml_custom_prices_strings', 'set_labels_for_price_fields', 10, 2 );<br /><br />add_filter( 'wcml_custom_prices_fields_labels', 'set_labels_for_price_fields', 10, 2 );<br />function set_labels_for_price_fields( $labels, $product_id ){<br />// Edit the label of a custom price field<br />$labels[ '_purchase_cost' ] = __( 'Purchase cost', 'woocommerce-multilingual' );<br />return $labels;<br />}<br /><br />add_filter( 'wcml_update_custom_prices_values', 'add_purchase_cost_to_custom_prices', 10, 3 );<br />function add_purchase_cost_to_custom_prices( $custom_prices, $code, $post_id ) {<br />    $type = get_post_type($post_id);<br />    if ( 'product' == $type ) {<br />        $purchase_cost = get_post_meta($post_id, '_purchase_cost' . '_' . $code, true);<br />               if (isset($_POST["_custom_purchase_cost"][$code])) {<br />            $purchase_cost = $_POST["_custom_purchase_cost"][$code];<br />        }<br />    } elseif ( 'product_variation' == $type ) {<br />        $purchase_cost = get_post_meta($post_id, '_purchase_cost' . '_' . $code, true);<br />        if (isset($_POST["_custom_variation_purchase_cost"][$code])) {<br />            $purchase_cost = $_POST["_custom_variation_purchase_cost"][$code][$post_id];<br />        }<br />    }<br />$custom_prices['_purchase_cost'] = $purchase_cost;<br />return $custom_prices;<br />}
If this solution does not resolve your issue or seems outdated, please check the related known issues and verify that you have installed the latest versions of themes and plugins. If the problem persists, we highly recommend opening a new support ticket at WPML support forum.
This topic contains 22 replies, has 0 voices.
Last updated by marioG-45 10 months, 3 weeks ago.
Assisted by: Dražen.
April 22, 2025 at 5:55 am #16953034
marioG-45
I am working on a site under development and trying to add an extra field using wcml_custom_prices_fields. The field appears properly, but after saving, its value does not appear. I am following the documentation at https://wpml.org/wcml-hook/wcml_custom_prices_fields/.
The extra field added using wcml_custom_prices_fields appears properly but does not retain its value after saving.
Why does the value of the extra field not appear after saving?
April 22, 2025 at 6:33 am #16953151
Dražen
I have been able to reproduce the issue and have escalated it to our 2nd tier to check and advise further.
Drazen
April 23, 2025 at 5:53 am #16957866
marioG-45
Any luck on that issue?
Please let me know.
April 23, 2025 at 6:09 am #16957874
Dražen
it will take a day or two before I have any feedback.
I will update you when I have some news.
Drazen
April 23, 2025 at 9:01 am #16958651
marioG-45
Hello
Thanks for your response. Waiting for good news 🙂
April 24, 2025 at 5:50 am #16962468
Dražen
[changing status of ticket]
April 24, 2025 at 12:01 pm #16964104
Dražen
we checked, and you will also need to use wcml_update_custom_prices_values hook, for example:
add_filter( 'wcml_update_custom_prices_values', 'add_sign_up_fee_to_custom_prices', 10, 3 );
function add_sign_up_fee_to_custom_prices( $custom_prices, $code, $post_id ) {
	$sign_up_fee = get_post_meta( $post_id, '_sign_up_fee'.'_' . $code, true );
    if (isset($_POST["_custom_sign_up_fee"][$code])){
        $sign_up_fee = $_POST["_custom_sign_up_fee"][$code];
	$custom_prices['_sign_up_fee'] = $sign_up_fee;
- https://wpml.org/wcml-hook/wcml_custom_prices_fields/
Drazen
April 28, 2025 at 4:58 am #16973051
marioG-45
Hello there
I'm using the wcml_custom_prices_fields hook to create a custom field and try to store data. The field appears in the product, but after saving, the data is not storing.
Documentation link: https://wpml.org/wcml-hook/wcml_custom_prices_fields.
My code: hidden link.
Backend Screenshot: hidden link.
Why is the custom field data not storing after saving? That changes will come in new plugin update?
Could you please check it and let me know.
April 28, 2025 at 11:33 am #16974601
marioG-45
Hi Dražen,
Are you there? I hope you are doing well.
Could you please check it on urgent basis.
April 28, 2025 at 6:38 pm #16976535
Dražen
I am not sure if you have maybe missed my reply above few days ago, you also need to use additional hook for prices to be saved / updated.
Please check my previous reply.
Let us know if anything else.
Drazen
April 30, 2025 at 4:02 am #16981559
marioG-45
Hello Dražen,
As per your previous comment I have added below code.
Did you checked my screenshot which I shared in previous comment. What you think I miss any hook or any code to save value?
April 30, 2025 at 4:30 am #16981566
marioG-45
Hello Dražen,
I found more issue in the variable product. its only showing the currency symbol not showing the field label. Also its not saving the value just like the previous response.
Screenshot - hidden link
You can check below video for more understanding.
- hidden link
April 30, 2025 at 5:29 am #16981603
Dražen
one thing at time please.
For code, I shared with you, as I have this is example code you need to adjust it to your custom field names.
So, to make it more understandable, use hook wcml_custom_prices_fields to create custom fields, then use wcml_update_custom_prices_values to update these fields.
Note I am on vacation today, so I might not reply until tomorrow. You can also open new chat and ask my colleague to help out in the meantime.
Drazen
April 30, 2025 at 11:08 am #16983370
marioG-45
I am trying to save custom field data for a WooCommerce variable product using the WPML plugin. I have added custom price fields using the following code:
return $fields;
return $labels;
$purchase_cost = get_post_meta( $post_id, '_purchase_cost'.'_' . $code, true );
if (isset($_POST["_custom_purchase_cost"][$code])){
After saving the variable custom field data, the product page reloads, and I can't see anything. When I comment out the code, things work fine, but I can't see the custom field.
Why does the product page reload and not display anything after saving the variable custom field data?
How can I save custom field data for a WooCommerce variable product without causing the page to reload incorrectly?
May 1, 2025 at 6:39 am #16985645
Dražen
thanks, I will need to check with our 2nd tier, since it could be different for variable products.
Drazen
