Our wait time is higher than usual, please make sure you are meeting the minimum requirement - https://wpml.org/home/minimum-requirements before you report issues, and if you can take a look at current Known Issues - https://wpml.org/known-issues/. Thank you.
Last updated by Itamar 2 days, 19 hours ago.
Assisted by: Itamar.
March 26, 2025 at 3:25 pm
liorM-3
I am building pages using custom Gutenberg blocks based on ACF fields. According to instructions, I created wpml-config.xml and made a schema for one block.
When I try to send the page translator, it still shows me one word to translate.
Why does the page translator only show one word to translate after setting up wpml-config.xml?
March 26, 2025 at 4:30 pm
March 26, 2025 at 4:33 pm #16864361
Itamar
Please get back to us if the problem persists with the latest stable versions of our plugins.
Itamar.
March 27, 2025 at 3:43 pm #16869457
liorM-3
Hi.
I've updated to the latest version and the problem still reproduce
March 30, 2025 at 11:33 am #16876388
Itamar
I'm consulting our second-tier supporters about this case and will update you once I receive their reply.
Meanwhile, it would be good if you could install your custom blocks on a sandbox site I created to see if the problem also occurs on a fresh WordPress + WPML installation. You can access it through this link:
I already configured WPML to have English as the default language and Dutch as the second language.
Important! Do not import your site to the test site. We must replicate the problem on a fresh, clean WordPress installation.
Itamar.
April 1, 2025 at 11:50 am #16882696
liorM-3
Hi Italamar. Can you provide me with FTP credentials? I need upload something
April 1, 2025 at 1:40 pm #16883248
Itamar
We don't have FTP access to those sandbox sites. However, I installed the WPFile Manager plugin; you can upload files using this plugin. Please see the attached screenshot.
Our second-tier supporter suggested checking the _wpml_word_count meta_key in the postmeta table. But I'll be able to check it once you proceed with replicating the problem on the sandbox site.
Itamar.
April 3, 2025 at 9:29 am #16890926
liorM-3
Hi.
Can you recreate the sandbox? Now show me the critical error and I can access any functionality
April 3, 2025 at 6:39 pm #16894616
Laura
Itamar is on vacation, so I'm covering for him.
I created a new Sandbox for you, please consider that trying to upload a copy of the site will indeed trigger a fatal error, so if it was what you were trying to to, it's expected.
April 6, 2025 at 1:05 pm #16901267
Itamar
I'm back and will continue to help you with this issue.
On the sandbox site, I configured WPML to have English as the default language and Dutch as the secondary language. I also installed ACF Pro on this site.
Are you able to replicate the problem there?
Itamar.
