Last updated by jorgeM-44 1 day, 2 hours ago.
January 4, 2025 at 6:42 pm #16563768
jorgeM-44
Hi Andreas,
1. WPML Custom Fields
SOLVED
2. Product page translation - Data and Short Description
Yes, but if I updated it blank, so if I remove the original post short description and then translate the product page, it should update the translated product page with also none short description, is that correct? Beucase it doesn't.
3. Product page translation - URL
Sure, it makes sense. SOLVED
4. WPML Editor - Draft
Thank you Andreas.
Best Regards,
Jorge
January 4, 2025 at 10:29 pm #16563892
I have escalated the "WC product Description and Product Short Description" issue towards our second tier support for further revision.
Take note that this is a ATE (Advanced Translation Editor) specific issue. It does not occur using the CTE (Classic Translation Editor).
Once I receive feedback from the team I will keep you updated.
January 7, 2025 at 1:26 pm #16569676
In case you would like to use a workaround for this issue, please edit the function save_package_to_job() inside the file .../wp-content/plugins/sitepress-multilingual-cms/classes/translation-jobs/class-wpml-element-translation-package.php
Change:
if ( array_key_exists( $field, $prev_translation ) ) {
  $job_translate['field_data_translated'] = $prev_translation[ $field ]->get_translation();
  $job_translate['field_finished']        = $prev_translation[ $field ]->is_finished( $value['data'] );
To:
if ( array_key_exists( $field, $prev_translation ) && !empty( $value['data'] ) ) {
January 8, 2025 at 10:59 pm #16575669
jorgeM-44
Thank you Andreas!
