This topic is split from https://wpml.org/forums/topic/css-broken-when-i-active-wpml/
Last updated by Bobby 1 year, 6 months ago.
Assisted by: Bobby.
May 9, 2023 at 1:19 am #13609311 | |
fernandoJ |
Hi, As you see in the attachment, the SMART 160 MMA in Spanish is correct, but in English the related products are not correct. |
May 9, 2023 at 1:20 am #13609313 | |
Bobby Supporter
Languages: English (English ) Timezone: America/Los_Angeles (GMT-08:00) |
Thank you for the screenshots! How do you configure the related products? Are you using the Woocomerce standard feature or a 3rd party plugin? |
May 9, 2023 at 9:17 am #13611731 | |
fernandoJ |
Hi, with the woocommerce standard feature. |
May 9, 2023 at 8:57 pm #13617583 | |
Bobby Supporter
Hello, Please verify that you have translated the product taxonomies and are correctly assigned to the translated product. If possible, re-share the access details with me as they were automatically removed. |
May 11, 2023 at 7:32 pm #13633127 | |
Bobby Supporter
Thank you, I can see the issue now. Go to a product with this issue and edit it in the default language (hidden link) Click on "productos relacionados" and you will see the tags Now use the language switcher in the top header and change to the translation (dismiss the warning) ---> you will notice the tags are missing. (hidden link) To resolve this I have set the following fields to 'copy' and it looks like it's working ok now _crp_related_ids For new translations, nothing needs to be done, but to make sure this change takes in effect for existing translations you will need to edit the default language product and "update". To expedite this you can go to Products->bulk select->bulk quick edit and update. |
