Problem: The client is unable to translate certain elements within their website using WPML. Specifically, they are having issues with translating the 'read more' button and pagination on the search results page, as well as translating and changing URLs in text links within the footer for different languages.
Solution: 1. We recommend using the String Translation plugin to translate the 'read more', 'next', and 'previous' strings that are not visible in the string translations.
2. For translating custom links in the footer, we suggest creating a custom language switcher. You can follow the instructions in our documentation on how to create a custom language switcher: Custom Language Switcher.
Additionally, we provided a screen recording that demonstrates the process of translating links: Screen Recording.
If this solution does not seem relevant to your issue, please do not hesitate to open a new support ticket with us for further assistance: WPML Support Forum.
Within WPML I see the option to translate all texts within a template part. This works well. However, there are also things that I cannot translate. This concerns in particular the following parts:
1.
I can partly translate the search results page. For each search result I have placed a "read more" button and pagination. Unfortunately I cannot translate these texts/links within WPML. See attachments
2
Another example: I'm trying to translate the footer. This also goes well with the texts, but there are a number of links to various websites. As an example I use a link to the wpml website (https://wpml.org/), but in the Dutch footer I would like to use the link https://wpml.org/nl, or hidden link. Unfortunately, I cannot achieve this within the WPML translation management.
1. Unfortunately I do not see the text "read more", "next", "previous" within the string translations. I don't see where I can change these texts.
2. No, this is not what I mean. In my footer I have placed a textlink (see attachment). I can translate the text of this link, but I can't edit the link to the website. Is it possible to also translate the link? I would like hidden link to be changed to hidden link in Dutch, so that Dutch visitors immediately taken to the correct website after clicking on the link.
Upon reviewing your debug information, I have observed that the PHP limit for your "WP Memory Limit" is lower than the recommended 256MB or the required 128MB, as mentioned in the documentation found at: https://wpml.org/home/minimum-requirements/. To resolve this, I kindly request that you contact your hosting provider and request an increase in the PHP value for you.
Also, please update the WPML Plugins to the latest version on your Website.
