Last updated by Bobby 1 year, 9 months ago.
Assisted by: Bobby.
May 9, 2023 at 1:19 am #13609311
fernandoJ
As you see in the attachment, the SMART 160 MMA in Spanish is correct, but in English the related products are not correct.
May 9, 2023 at 1:20 am #13609313
Bobby
Timezone: America/Los_Angeles (GMT-08:00)
Thank you for the screenshots!
How do you configure the related products? Are you using the Woocomerce standard feature or a 3rd party plugin?
May 9, 2023 at 9:17 am #13611731
fernandoJ
Hi, with the woocommerce standard feature.
May 9, 2023 at 8:57 pm #13617583
Bobby
Please verify that you have translated the product taxonomies and are correctly assigned to the translated product.
If possible, re-share the access details with me as they were automatically removed.
May 11, 2023 at 7:32 pm #13633127
Bobby
Thank you, I can see the issue now.
Go to a product with this issue and edit it in the default language
(hidden link)
Click on "productos relacionados" and you will see the tags
Now use the language switcher in the top header and change to the translation (dismiss the warning) ---> you will notice the tags are missing.
(hidden link)
To resolve this I have set the following fields to 'copy' and it looks like it's working ok now
_crp_related_ids
_crp_related_product_cats
For new translations, nothing needs to be done, but to make sure this change takes in effect for existing translations you will need to edit the default language product and "update".
To expedite this you can go to Products->bulk select->bulk quick edit and update.
