Our next available supporter will start replying to tickets in about 7.54 hours from now. Thank you for your understanding.
We have a longer than usual waiting time. Please make sure to check out the Known Issues page and Minimum Requirements before reporting any issue.
Supporter timezone: Europe/Madrid (GMT+01:00)
Last updated by Carlos Rojas 11 hours, 18 minutes ago.
Assisted by: Carlos Rojas.
November 8, 2024 at 2:18 pm #16382398
oliverB-50
I am trying to translate extensive Elementor pages using WPML, with around 250 items needing translation. The complexity of these pages results in a larger DOM size. We have implemented a workaround by using templates to split page content, making translation easier. I suspect some custom code might also be contributing to the problem.
Elementor pages are unable to save translations, potentially due to the high number of elements. WPML’s health check shows all indicators in the green, but there is a single ATE error related to authentication in the debug log.
Is there a specific limit on the number of elements that can be translated with WPML and Elementor?
Is there a better way to verify the issue with saving translations?
November 8, 2024 at 3:13 pm #16382693
Carlos Rojas
Thank you for contacting us
I would like to ask you to share the error message (or a screenshot where the error can be seen) so we can gather more information about this behavior.
Also, could you tell me if the issue doesn't happen with a new (smaller) test page?
Carlos
November 8, 2024 at 3:16 pm #16382701
oliverB-50
Hola Carlos, thank you for answering. As for error message there is no error message displayed. It reloads the page overview page, and still keeps it in the settings wheel (not the pen icon), and then the elements are simply not translated.
Oly
November 11, 2024 at 10:32 am #16387892
Carlos Rojas
Hi Oly,
1.- I would like to reproduce the issue on the site to obtain more information about it. I have set your next message private so you can securely share the access credentials to the site.
Please don't forget to create a full backup of the site before sharing the credentials.
2.- Also, I kindly ask you to share the page URL where the issue can be seen.
November 16, 2024 at 9:24 am #16410394
oliverB-50
Hola Carlos, thank you for your response. Due to data privacy reasons it's more difficult for me to give out the site access. Do you have also a more general answer? Something like "WPML works for pages of a DOM size of X" or considering another metric?
Best
Oly
November 16, 2024 at 10:09 am #16410472
Carlos Rojas
Hi Oly,
WPML should work with any page size 🙂
To be able to provide an answer I would need to activate the debug log and check if there are any errors, especially PHP limitations, and get one of the ATE translation jobs URLs to check on our side.
Is it possible for you to create a staging site with a copy of the live site and give us access to run all these tests without affecting the production site?
