Last updated by Andreas 1 year, 10 months ago.
Assisted by: Andreas.
January 20, 2023 at 10:00 am #12857931
dennisv-7
Is it possible to exclude some posts from the auto translator? So it skips those post.
Let me know.
January 20, 2023 at 10:10 am #12857967
Hello there
Thank you for contacting us. I am happy to help you.
Right now you cannot exclude specific posts from an automatic translation. What you can do though is to disable the Translate Everything feature, and bulkd send the posts you wish for automatic translation.
https://wpml.org/documentation/automatic-translation/automatically-translating-multiple-translation-jobs-in-bulk
I hope this helps. Please let us know how it goes or if you need any further assistance. I'll gladly help you. 🙂
January 20, 2023 at 10:14 am #12857975
dennisv-7
Hello Andreas,
Thanks for the quick reply.
Will this option be added in a (near) future update? Or do you not know that at the moment?
January 20, 2023 at 11:05 am #12858299
Thank you for your reply.
The only feature that would be available in the next version of WPML will be :
If you go inside a post and disable WPML Translation Editor ( that means that those posts will use Native WordPress Editor ) , then those posts will be excluded from Translate Everything Mode.
I hope this clarifies things to you.
January 20, 2023 at 11:20 am #12858465
dennisv-7
Alright! That sounds like a solution to me. I'll await the update and try it.
Thanks for all the help.
January 20, 2023 at 11:27 am #12858509
You are very welcome. I am closing the ticket now, if you need anything else do not hesitate to contact us again.
