This topic contains 7 replies, has 3 voices.
Last updated by andreaB-8 1 year, 10 months ago.
Assisted by: Bobby.
April 18, 2023 at 10:36 pm #13500043
andreaB-8
In this site
footer seems that is not translated... can you assist me for approach in right way?
I checked different tutorial in your site but I want to follow right steps.
April 19, 2023 at 6:50 am #13501855
Dražen
can you please share some images or videos on how are you adding and creating this footer in the default language?
Drazen
April 19, 2023 at 2:31 pm #13505487
andreaB-8
I tried to search in Menu but I don't know how to change footer items in this site
April 19, 2023 at 8:41 pm #13507857
Bobby
It looks like the footer is created using widgets. Go to Appearance->Widgets and let me know if you see the footer items listed there.
If yes, follow the steps from this documentation:
https://wpml.org/documentation/getting-started-guide/translating-widgets/#using-different-widgets-for-different-languages
April 19, 2023 at 9:01 pm #13507945
andreaB-8
Yes but how to translate these widgets... according that now I've only IT section
April 21, 2023 at 4:39 am #13514995
Bobby
Thank you,
Bobby
April 25, 2023 at 1:27 am #13530373
Bobby
Your Footer is compromised of 6 widgets.
You can locate these widgets in Appearance->Widgets
They are named:
Footer Top Column 1
Footer Top Column 2
Footer Top Column 3
Footer Top Column 4
Footer Bottom Column 1
Footer Bottom Column 2
For example, Footer Bottom Column 1 has a text widget with this content
"ALTOPIANO DEL SOLE - Tutti di diritti sono riservati.  Piattaforma Sviluppata da Area Élite PISOGNE - Supporto Tecnico LIMES FARM"
See the screenshot I shared---> Where it says " Display on language" at the moment it's set to "all languages" -> set it to "Italian" -> add another Text widget right underneath it and set it to "English" in the English one add your translated content
For the menu go to Appearance->Footer Menu->Click on synchronize menus between languages or click on the "+" icon to add the translation.
Documentation on how to translate widgets:
Documentation on how to translate menus:
https://wpml.org/documentation/getting-started-guide/translating-menus/
