Last updated by Kor 1 year, 10 months ago.
April 2, 2023 at 12:40 am #13381975
ronaldT-5
Tell us what you are trying to do. Translate from English to French and not screw up the Elementor interface. French takes a lot more room than English. I never know what character size to use when creating pages in English.
Is there any documentation that you are following? No
Is there a similar example that we can see? No
April 3, 2023 at 8:00 am #13387569
Please try duplicating the page first before translating it. You can refer to the instructions here https://wpml.org/documentation/translating-your-contents/displaying-untranslated-content-on-pages-in-secondary-languages/#duplicating-content on how to duplicate translations.
Using this method will allow you to copy the options into the translated page, preventing the issue you're encountering.
Could you give this a try and see if it helps?
April 10, 2023 at 6:44 pm #13439563
ronaldT-5
Sorry for the delay in responding. My laptop died on me, and I had to purchase a new one, and relearn how to walk again, so to speak. I acquired a Mac, for the first time.
The solution brought forward does absolutely nothing to resolve my issue.
When I create my ENGLISH website pages using WordPress with Elementor Page Builder, I tend to use the largest text font sizes to make things look good. But, after translating the pages into French via WPML, many of the pages headings and sub-headings don't fit the allocated space, breaking up into two lines.
Hope it is clearer! Is there a solution for this?
-Ronƒ
April 11, 2023 at 6:19 am #13441931
Thanks for your reply.
I would need to take a closer look at your site. So I would need to request temporary access (WP-Admin and FTP) preferably to a test site where the problem has been replicated if possible in order to be of better help and check if some configurations might need to be changed
IMPORTANT: Please, note, a backup is required for security reasons, and to avoid any data loss, you can use the https://wordpress.org/plugins/updraftplus/plugin for these backup needs.
Your following answer will be private, which means only you and I have access to it.
✙ I would need your permission to de-activate and re-activate Plugins and the Theme and to change configurations on the site if required. This is also a reason the backup is critical.
The topic ‘[Closed] How to work with Elementor using WPML?’ is closed to new replies.
