The client is experiencing slow loading and saving times for pages and posts after installing WPML, along with technical errors reported by WordPress.
We recommend trying the minimum environment procedure to identify if the issue is due to a conflict with the theme or another plugin. Here are the steps:
1. Switch to a default WordPress theme, such as TwentyTwenty-Four.
2. Deactivate all plugins except for WPML and its add-ons.
3. Check if the problem persists. If it does not, reactivate the plugins one by one to identify the problematic plugin.
It's crucial to make a full site backup before proceeding with these steps. If your site is live, consider performing these tests in a staging environment.
If the issue persists even when WPML is deactivated, it suggests that the problem might not be with WPML. In this case, enable WordPress's debug log to gather more information about the errors. You can enable debugging by modifying your wp-config.php file:
define('WP_DEBUG', true);<br />define('WP_DEBUG_LOG', true);<br />define('WP_DEBUG_DISPLAY', false);<br />@ini_set('display_errors', 0);After enabling debugging, reproduce the actions causing the slowness and check the debug.log file in the /wp-content/ directory for errors.
If these steps do not resolve the issue, or if the solution seems outdated or irrelevant to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket with us for further assistance.
Last updated by Itamar 1 year, 8 months ago.
Assisted by: Itamar.
| Author | Posts |
| August 4, 2024 at 7:09 am #16036167 | |
juergenS-23 |
<b>Hintergrund des Themas: </b> <b>Die Symptome: </b> <b>Fragen: </b> This is what my wp-config.php looks like: -- removed by the support team -- Question: where do I add the code for: |
| August 4, 2024 at 7:23 am #16036176 | |
juergenS-23 |
I have now inserted the memory limit setting correctly in the wp-config.php, but the load speed issue persists. Even after setting it to 256. |
| August 4, 2024 at 6:54 pm #16037104 | |
Languages: Hebrew (עברית ) Timezone: Asia/Jerusalem (GMT+03:00) |
Hi, I'm consulting our second-tier supporters about the error you're getting. I'll update you here once they reply. Regards, |
| August 5, 2024 at 12:00 pm #16039541 | |
Hi, Our second-tier supporter suggests trying the minimum environment procedure. We suspect that a collision with the theme or another plugin might cause this problem. If possible, get your site into a minimum environment, switching to a default WordPress theme like TwentyTwenty-Four and having no plugins activated except WPML. First, you must check if the problem persists when just the theme is switched to TwentyTwenty-Four (for example). If it persists, deactivate all plugins except the WPML and its add-ons. Then please check if the problem persists. If it does not persist, start by activating the plugins individually and check when the problem comes back, then report to me which plugin was the culprit.
| August 6, 2024 at 5:37 am #16042449 | |
juergenS-23 |
I did deactivate all plugins and switched to the base WP theme. The problem is still the same. |
| August 6, 2024 at 10:28 am #16043473 | |
Hi, and thanks for trying my suggestions. If the slowness proceeds when WPML is deactivated, then the problem is not with WPML. Please also investigate in other direction and consult the support of your hosting service. Of course, we will continue to help you investigate whether WPML is causing any performance issues on your site. While WPML is active, please enable WordPress's debug log and check for PHP errors. Please check this page for instructions. https://wpml.org/documentation/support/debugging-wpml/ To enable it, open your wp-config.php file and look for
define('WP_DEBUG', false);
Change it to:
After this, repeat the action that causes the problem on your site. Visit a few pages where the performance (slowness) issue occurs. The errors will be saved to a debug.log log file inside the /wp-content/ directory. Then please share the errors with us. Thanks, |
| August 6, 2024 at 11:09 am #16043592 | |
juergenS-23 |
I had changed my wp-config to this already but the site isn't displaying any errors. |
| August 6, 2024 at 11:57 am #16043726 | |
Hi, and thanks for trying my suggestions. Please try the troubleshooting section and check if it helps with the performance issue while WPML is active. 1. Take a backup of the DB of your site. 2. Go to WPML -> Support -> Troubleshooting (link) 3. Once on the troubleshooting screen, press the following buttons and check if it helps. Press each button at a time and wait for the process to complete. - 'Disable cache for language switcher templates' - 'Clear language information and repopulate languages' button (if it is showing) - 'Synchronize posts taxonomies' for all the different post types - 'Clear the cache in WPML' - 'Remove ghost entries from the translation tables' - 'Fix element_type collation' - 'Fix WPML tables collation' - 'Synchronize local job ids with ATE jobs' - 'Synchronize translators and translation managers with ATE' - 'Assign translation status to duplicated content' - 'Set language information' - 'Reset languages' Press this button only if you didn't add a custom language! - 'Fix terms count' - 'Fix post type assignment for translations' - 'Cleanup and optimize string tables' - 'Clear invalid strings' *** Please backup your database before using this.*** Does it help to improve your site's performance when WPML is active? Please also take a look at the following guide on how we debug performance issues. https://wpml.org/faq/prevent-performance-issues-with-wpml/ Regards, |
| August 16, 2024 at 8:32 am #16077352 | |
juergenS-23 |
I had to rebuild that site from scratch (because of my mistake publishing sensitive data - someone used that data to hack the site, before you intervened and deleted that content...). That said, we have a few sites where we are experiencing the same issues. Unfortunately, for those sites, we cannot just use a different theme, because it is a custom one developed by my team. For those websites, WP keeps sending reports about issues on the site that are WPML related. I am pasting the details here - could you please take a look and see if you have any additional suggestions as to what might cause them? Error Details |
| August 18, 2024 at 5:50 pm #16081715 | |
Hi, According to another report, the error message resembles the error you shared, so it might be a problem in the site's database. The table wp_icl_translations is corrupt. The client restored the site from a backup in that ticket, which solved the problem. But if you can't do that, we can try to help. This ticket initially concerned another problem on another website. Please open a new ticket in our forum and add the details of the related website. It would be helpful if you mentioned this ticket in the new ticket. Regards, |
