Products page layout is changed in the backend after installing the WPML plugins.
This issue usually happens when the Yoast SEO plugin is adding a few more columns to the product page and the size of these new items doesn't really fit the layout. You can fix this issue by going to Dashboard >> Products, clicking the Screen Options button from the top right corner of the page, and unchecking a few columns that you don't need like “SEO Title”. This way, fewer columns will remain and everything should look fine again.
https://cdn.wpml.org/wp-content/uploads/2023/03/13225021-Screen_options_1.png
Last updated by sajedO-2 1 year, 10 months ago.
Assisted by: Noman.
March 11, 2023 at 7:21 am #13222221
sajedO-2
I am trying to: trying get my website back to normal
I expected to see: sovle the problem
Instead, I got:
each product in wood commerce looks very tall after installing WPML
March 12, 2023 at 9:00 am #13225021
Noman
Thank you for contacting WPML Support. This issue usually happens when the Yoast SEO plugin is adding a few more columns to the product page and the size of these new items doesn't really fit the layout. You can fix this issue by going to Dashboard >> Products, clicking the Screen Options button from the top right corner of the page, and unchecking a few columns that you don't need like “SEO Title”. This way, fewer columns will remain and everything should look fine again.
Please let me know if this resolves your issue or if you need further assistance.
Thank you
