The client reported that the navigation and footer disappear when selecting the German version of their site.
For the navigation logo issue, we recommended creating a new HTML widget under WP > Appearance > Widgets > Logo and pasting the same HTML there, but selecting the German language for the "Display on Language" option. Here is the HTML code used:
<a href="https://semistaal.com/?lang=de" aria-label="Back to home" class="uk-logo uk-navbar-item"><img alt="DevStack" loading="eager" width="310" height="60" src="/wp-content/uploads/2021/07/semi-staal-logo-web.svg"/><img class="uk-logo-inverse" alt="DevStack" loading="eager" width="310" height="60" src="/wp-content/uploads/2021/07/semi-staal-logo-web.svg"/></a>
Regarding the missing footer, we requested more information on how the client created the footers for the Danish and English versions, which were accessed through WP > Yootheme > Widgets > Bottom.
Last updated by jeanetteH-3 3 days, 19 hours ago.
February 18, 2025 at 9:54 am #16717806
jeanetteH-3
Thank you so much Kor!
It helped, however, our navigation and footer disappear when we select the German version of the site - can you tell me what the problem is?
February 18, 2025 at 4:14 pm #16720106
Thanks for your reply.
I was able to fix the Logo issue in German language in WP > Appearance > Widgets > Logo > Create a new HTML widget and paste the same HTML there. Then, I selected the German language for the "Display on Language" option as shown in the attached screenshot.
As for the missing footer, I still need more information on how you created the footer for your Danish and English language earlier. I accessed it through WP > Yootheme > Widgets > Bottom. It shows that you've created Footer DK and Footer UK as shown in the attached screenshot.
How and where do you create that?
Pasted HTML in German language Widget :
<a href="<em><u>hidden link</u></em>" aria-label="Back to home" class="uk-logo uk-navbar-item">
<img alt="DevStack" loading="eager" width="310" height="60" src="/wp-content/uploads/2021/07/semi-staal-logo-web.svg"><img class="uk-logo-inverse" alt="DevStack" loading="eager" width="310" height="60" src="/wp-content/uploads/2021/07/semi-staal-logo-web.svg"></a>
February 25, 2025 at 4:45 pm #16747161
jeanetteH-3
Thank you so much for your help kor! I got it working 🙏🏻
