This topic contains 8 replies, has 3 voices.
Last updated by Prosenjit Barman 1 year, 10 months ago.
May 10, 2023 at 9:41 am #13620309
truthW
We are using WPML and youzify in our website.
We need to help us find out how we can translate the titles of the tabs that have been created in Youzify - Profile Settings - Tabs Settings.
May 10, 2023 at 9:58 am #13620567
Mihai Apetrei
Hi there.
Before this ticket gets assigned to my colleagues, I will try to help.
The proper way to translate strings depends a lot on how they have been implemented inside the theme/plugin.
Sometimes, there are even duplicates of the same string and only one of them is the correct one that needs to be translated.
Also, sometimes, simply removing the string (checking the box and removing it) and then re-registering it again by scanning for it (one of the methods below) and re-translating it resolves the issue.
1. Please try this:
Go to WPML > String Translation and at the bottom of the page you will find a checkbox called "Look for strings while pages are rendered". You can enable (check) that and then go in the front end to a page where you have that string showing up and then go back to WPML > String Translation and search for that string and see if it now shows up.
2. If you can't find them inside the WPML > String Translation, they might be added as admin text.
This should be the normal process to find and translate admin text strings:
https://wpml.org/documentation/getting-started-guide/string-translation/finding-strings-that-dont-appear-on-the-string-translation-page/
Please let us know how that goes.
Kind regards,
Mihai Apetrei
May 10, 2023 at 12:40 pm #13622597
truthW
Thank you for the reply.
We tried the method you suggested but still no available string for translation.
May 11, 2023 at 11:40 am #13629983
Prosenjit Barman
Hello There,
Thanks for trying out the suggestions. I'd like to inform you that the theme you're using is not listed as compatible in the WPML's compatible theme directory. But, if the theme developers have added the proper translation support for those texts, then those should appear properly in String Translation. Can you please confirm that you have checked by following the steps below?
- Navigate to "WPML > Theme and Plugins localization" and scanned the "Olympus" theme for strings.
- After completing the scan, go to "WPML > String Translation" and search for the texts.
If the texts are not appearing in the String Translation even after that, then a closer inspection will require to understand the root cause. I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue.
It would be better to have a testing site where the issue is replicated.
IMPORTANT
-Please make a backup of site files and database before providing us access.
Best Regards,
Prosenjit
May 12, 2023 at 6:35 am #13634267
truthW
We have followed the steps you suggested but still no luck.
As you can see in:
They say that the theme is compatible with WPML
Compatible With bbPress 2.6.x, bbPress 2.5.x, BuddyPress 10.x.x, BuddyPress 9.x.x, Elementor, Elementor Pro, Events Calendar, Events Calendar Pro, Gravity Forms, WooCommerce 7.x.x, WooCommerce 6.x.x, WPBakery Page Builder, WPML, Bootstrap 4.x
May 15, 2023 at 9:30 am #13646431
Prosenjit Barman
Hi There,
I hope you're doing well. Sorry for the delay in responding.
Although the theme claims to be compatible with WPML, it's possible that the developers have not contacted us for compatibility testing. This could be the reason why the theme is not listed in our directory of compatible themes.
Please check by going to this link- https://wpml.org/theme/?wpv_view_count=119967&wpv-theme-category=0&wpv_post_search=Olympus&wpv-wpcf-recommendation-flag=&wpv_filter_submit=Search
However, I checked the Tab section of your site again and found that the Tab titles are now showing translated. Please check this screenshot(hidden link) for a better understanding.
As the Tab title is appearing as expected, has the suggestions worked? Please ket me know if you need any further assistance in this matter. I will be happy to assist you.
Best Regards,
Prosenjit
May 15, 2023 at 1:55 pm #13648653
truthW
For the time being we translated the tab labels using a small javascript.
Not the correct way.
May 16, 2023 at 7:46 am #13652829
Prosenjit Barman
Hi There,
Thanks for sharing how they are translated. Since you still need help in this matter, I will be happy to check and help you to find a solution.
Would it be possible for you to grant me access to the site where you're experiencing the issue for further investigation? It will be better to share access to the testing site where the issue is replicated.
I've enabled the private box for you so that you can securely share access to your site. The private box looks like this:
Best Regards,
Prosenjit
May 18, 2023 at 7:41 am #13669497
Prosenjit Barman
Hello There,
Thanks for sharing the access.
Upon examining the Youzify plugin's tab configuration section, I found that the tabs on the Profile page were created using the "Custom Tab" feature of Youzify, and then the tab title was added dynamically from the "Tabs setting" section of Youzify.
Currently, the Youzify plugin has integrated WPML support for various dynamic tab titles. However, unfortunately, this support has not been implemented yet for the custom-created tabs. As a result, the titles of these tabs do not appear for translation anywhere within the plugin.
You can find the list of tab titles that have received WPML support and can be translated by visiting the following link: hidden link
I have conducted further research and discovered documentation on translating dynamic words in the Knowledgebase of the Youzify plugin. Unfortunately, they are supporting a few dynamic words only and the possibility of Translating the Custom tab titles is also not included there. You can check the guide below if you want.
- hidden link
Since the support for Custom Tab titles has not been implemented yet, it is necessary to bring this matter to the attention of the Youzify author/developers. It would be beneficial if you could reach out to the Youzify team directly to request their assistance in resolving this issue. They should be able to provide guidance and address the issue.
You can also request them to join our Go Global program to make their plugin fully compatible with WPML. You can check and share the link below for further information.
- https://wpml.org/documentation/support/go-global-program/
I hope you can understand the matter. But, feel free to reach us if you need any clarification or assistance. I will be happy to help you.
Best Regards,
Prosenjit
