I can't make some ACF fields translatable. These fields are locked
Please see this video:
https://www.loom.com/share/b0fded37756b436a99a0f37a8606e9a3
Under WPML settings, and search through all the settings and change the fields that had "content" in it to translatable.
Then:
1- Edit the product in the original language
2- Do a slight change somewhere (add space or dot anywhere)
3- Hit save (this will trigger WPML to detect that you need to update the translation for the product)
4- Retranslate it
5- Do you see those fields as translatable?
Relevant Documentation:
Last updated by 1 year, 10 months ago.
Assisted by: Ilyes.
