Last updated by marnixr-3 4 years, 9 months ago.
Assisted by: Mihai Apetrei.
April 15, 2020 at 11:06 am #5912545
marnixr-3
I'm trying to translate my ninja form.
But somehow it doesn't show up in the translation dashboard.
I scanned al translatable plugins etc. but this ninja is hiding too well.
how can I fix this?
April 15, 2020 at 2:47 pm #5914995
Mihai Apetrei
Hi and thank you for contacting WPML Support!
I will be happy to help you with this.
First of all, thank you very much for your patience and sorry to have you waiting - there is a very full ticket queue at the moment and it takes us a bit more than usual to answer tickets.
Now, regarding your request, I think you might have forgotten to install the add-on that's needed to find the forms and translate them with WPML Translation Management (https://wpml.org/documentation/related-projects/creating-multilingual-forms-using-ninja-forms-and-wpml/#getting-started).
It's called "Ninja Forms Multilingual" and you should be able to download it from here after you log in with your WPML.org account: https://wpml.org/account/downloads/
After you install the plugin and activate it, when you go back to WPML > TM, you should be able to see the ninja forms inside that dropdown, too.
Kind regards,
Mihai Apetrei
April 16, 2020 at 6:21 pm #5926585
marnixr-3
It turned out that I had installed the WPML before I installed ninja forms..
After removing the WPML-ninja plugin and installing it again it worked
