After migrating from qtranslate to WPML, the client noticed that while the English translations are visible on the frontend, they do not appear in the WPML editor for pages; however, articles are displayed correctly.
The issue arises because the translations were manually created without using WPML's translation workflow, leading to no data being associated with these translations in the Classic Translation Editor. We recommend two potential solutions:
1. Switch to the Advanced Translation Editor (ATE), which supports automatic translation. This change might require retranslation and could incur translation credit costs. For more details on how to switch, visit Switching from Classic to Advanced Translation Editor.
2. Continue using the Classic Translation Editor if you prefer full control over the translations, though this method is less convenient and more manual.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should you need further assistance, please open a new support ticket at WPML support forum.
This topic contains 24 replies, has 0 voices.
Last updated by myleneG 9 months, 1 week ago.
July 4, 2025 at 2:42 pm #17202257
myleneG
I have completed the migration from qtranslate to WPML. After the migration, I noticed an issue with the translations in the editor.
The English translated content is visible on the frontend, but when I use the editor, the texts are in the original language (French). This issue only applies to pages, while articles are fine.
Why are the translations not visible in the WPML editor for pages?
How can I ensure that the translated content appears in the editor as well?
Although I can still edit by going to english pages, it is a risk someone uses editor and erases translations.
thank you
July 7, 2025 at 10:49 am #17207878
Thanks for contacting us. You can manually edit the translated page, but please note that doing so will disable the use of the translation editor for that page in the future, as explained here: https://wpml.org/documentation/translating-your-contents/using-different-translation-editors-for-different-pages/
To check why the translations aren’t reflecting on the translated page, I’ll need to closely examine your website. Therefore, I will require temporary access (WP-Admin and FTP) to a test site where the problem has been replicated, if possible. This will enable me to provide better assistance and determine if any configurations need to be modified.
July 7, 2025 at 5:00 pm #17210508
Thanks for your reply. I've checked your primary language homepage here, and the "Become a volunteer" text is being translated to "Devenir bénévole" as shown in the attached screenshot. Am I looking at the correct page?
July 7, 2025 at 5:52 pm #17210647
myleneG
All the pages have the same problem The current page you are on is the home page.
Translations are visible in the front end, they are just not in the WPML editor (see screenshot shared)
Just note that I had to deactivate theme as it caused a problem, so dont mind the current look of things, I'm updating a very old, obsolete website.
So if I click on the pencil to change the translation in the Pages page, the translations are not there and if i save as is, I would lose them all. The sole current solution being to copy from front end to backend for each page, must be a way to remap those translations since they are somewhere in system?
Thank you
July 8, 2025 at 8:58 am #17212585
Thanks for your reply. Is this only affecting the homepage? Because when I checked other pages, it seemed fine. Also, please consider switching to the Advanced Translation Editor as it offers better features as explained here. https://wpml.org/documentation/translating-your-contents/using-the-translation-editor/switching-from-classic-to-advanced-translation-editor/
July 8, 2025 at 12:56 pm #17214015
myleneG
I had actually tried advancesd translations first and I restored a backup as it seemed worse and reverted to the old ways.
And it does that for all pages, i just checked the 5 first and some of them do have the title right, so please look further down to see what I'm saying, also 2 screenshots.
Thank you
July 8, 2025 at 1:48 pm #17214313
myleneG
Second problem this morning. I do have to say honestly, I have always been the only person managing a site and it always annoyed me to have any translation management but up to now, I managed to get by nonetheless by simply ignoring it.
However, I just tried modifying the menu and the button (I was in the original language, french which is weird) was Submit for revision (soumettre pour relecture). I tried it and now I have also lost all the existing translations, which are, in this case, just an alignment of pages with their translated counterpart, shouldn't have to do this manually?
July 9, 2025 at 8:09 am #17217389
I'm still checking on the wrong contents in the Classic Translation Editor for this page hidden link . Not sure why this is happening and I will need to investigate this further.
I regret any inconvenience caused, but to proceed with troubleshooting, I kindly ask for a snapshot of the site. Alternatively, with your permission, I can create one myself. For this purpose, I typically recommend using the free plugin "Duplicator." If you're already familiar with Duplicator (https://wordpress.org/plugins/duplicator/), please skip the following steps and simply send me the archive file you downloaded.
As for your second issue regarding the "I have also lost all the existing translation", could you tell me which page you are working on?
July 11, 2025 at 6:17 pm #17229186
Thanks for your patience. I have a copy of the site and will check it shortly. I’ll get back to you as soon as possible.
July 14, 2025 at 5:40 pm #17235174
Thanks for your reply. I'm still having trouble identifying the cause of the missing translations. Could you please restore the staging site hidden link to an earlier state, prior to any changes I made? Also, kindly update the credentials.
My apologies for the inconvenience. If I'm unable to resolve the issue this time, I’ll escalate it for further investigation.
July 16, 2025 at 1:11 pm #17242069
myleneG
Hoping the the sandbox site is still good as I did quite a bit of work on it. However this morning I upgraded php to 8.3. I don't know if it's because of this that I now get this error. I had to deactivate wpml.
I will also be sending you the backup from July 6th soon
Fatal error: Uncaught Error: Class "DOMDocument" not found in /home/oinlk951/sandbox.jaquebec.org/wp-content/plugins/sitepress-multilingual-cms/classes/xml-config/class-wpml-xml-config-validate.php:67 Stack trace: #0 /home/oinlk951/sandbox.jaquebec.org/wp-content/plugins/sitepress-multilingual-cms/classes/xml-config/class-wpml-xml-config-validate.php(51): WPML_XML_Config_Validate->get_xml() #1 /home/oinlk951/sandbox.jaquebec.org/wp-content/plugins/sitepress-multilingual-cms/classes/xml-config/class-wpml-xml-config-validate.php(34): WPML_XML_Config_Validate->from_string() #2 /home/oinlk951/sandbox.jaquebec.org/wp-content/plugins/sitepress-multilingual-cms/classes/xml-config/read/class-wpml-xml-config-read-file.php(18): WPML_XML_Config_Validate->from_file() #3 /home/oinlk951/sandbox.jaquebec.org/wp-content/plugins/sitepress-multilingual-cms/classes/xml-config/class-wpml-config.php(322): WPML_XML_Config_Read_File->get() #4 /home/oinlk951/sandbox.jaquebec.org/wp-content/plugins/sitepress-multilingual-cms/classes/xml-config/class-wpml-config.php(45): WPML_Config::parse_wpml_config_files() #5 /home/oinlk951/sandbox.jaquebec.org/wp-content/plugins/sitepress-multilingual-cms/classes/xml-config/class-wpml-config.php(35): WPML_Config::load_config_run() #6 /home/oinlk951/sandbox.jaquebec.org/wp-content/plugins/sitepress-multilingual-cms/inc/translation-management/translation-management.class.php(267): WPML_Config::load_config() #7 /home/oinlk951/sandbox.jaquebec.org/wp-includes/class-wp-hook.php(324): TranslationManagement->init() #8 /home/oinlk951/sandbox.jaquebec.org/wp-includes/class-wp-hook.php(348): WP_Hook->apply_filters() #9 /home/oinlk951/sandbox.jaquebec.org/wp-includes/plugin.php(517): WP_Hook->do_action() #10 /home/oinlk951/sandbox.jaquebec.org/wp-settings.php(727): do_action() #11 /home/oinlk951/sandbox.jaquebec.org/wp-config.php(105): require_once('/home/oinlk951/...') #12 /home/oinlk951/sandbox.jaquebec.org/wp-load.php(50): require_once('/home/oinlk951/...') #13 /home/oinlk951/sandbox.jaquebec.org/wp-admin/admin.php(35): require_once('/home/oinlk951/...') #14 /home/oinlk951/sandbox.jaquebec.org/wp-admin/plugins.php(10): require_once('/home/oinlk951/...') #15 {main} thrown in /home/oinlk951/sandbox.jaquebec.org/wp-content/plugins/sitepress-multilingual-cms/classes/xml-config/class-wpml-xml-config-validate.php on line 67
July 16, 2025 at 6:41 pm #17243445
Thanks for your reply. My apologies for that. Let me know if you can share a copy of the backup with me.
July 16, 2025 at 6:43 pm #17243447
myleneG
server is crap, keep getting a 500
July 17, 2025 at 7:14 pm #17247855
myleneG
July 17, 2025 at 7:19 pm #17247862
Thanks for sharing the files. I've just downloaded it and I will check and come back to you as quickly as possible.
