WordPress 6.7 has introduced a new issue that impact translations, please update WooCommerce and WPML to the latest versions before you report issues. More about this here - https://wpml.org/errata/php-error-wp-6-7-notice-function-_load_textdomain_just_in_time-was-called/
This topic contains 34 replies, has 0 voices.
Last updated by Kor 1 week, 3 days ago.
October 9, 2024 at 8:06 am #16268404
Vladimir
I am trying to add a translation to the master page. The default language on my site is English, but when I choose to translate the page, it sets the original language to Italian instead of English. You can see the issue on this page: hidden link
The original language is set to Italian instead of English when translating the page. I expected the translation to be from English to Norwegian, but it is from Italian to Norwegian.
Why is the original language set to Italian instead of English when translating?
How can I ensure the translation is from English to Norwegian?
October 9, 2024 at 2:54 pm #16271333
Osama Mersal
Thank you for contacting WPML support. Before your ticket is assigned to one of my colleagues, please allow me to walk you through some initial debugging steps. This will help speed up the support process.
Would you please share screenshots or a screen-recorded video while reproducing the issue?
Osama
October 10, 2024 at 11:30 am #16274522
Vladimir
Default language on the website is english(screenshot: wpml1.png), on every translation original language is english(screenshots: wpml2.png,wpml3.png), only when Norwegian language is being translated it sets the original language as Italian(screenshot: wpml4.png), this should be resolved, we need to have the english source(original language) on Norwegian translation aswell.
October 11, 2024 at 6:17 am #16277544
Thanks for your reply.
October 11, 2024 at 10:56 am #16278930
Vladimir
Also, when you go and try translate the german language through translation editor it fills it with english content, despite the fact that the german is already translated
October 11, 2024 at 3:53 pm #16280511
I've checked your homepage here hidden link and when I click on the Italian page, it crashes as shown in the attached screenshot.
Could you please reduce the PHP version to 8.2 or below?
October 14, 2024 at 7:46 am #16284264
Vladimir
Hey it's changed to 8.1, you can check
October 14, 2024 at 8:44 am #16284529
I'm getting this error now. Looks like you have insufficient memory on the server. Could you check?
[14-Oct-2024 08:43:18 UTC] PHP Fatal error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 372736 bytes) in /home/forge/mip.the-northwest.com/public/wp-includes/class-wpdb.php on line 2315
October 15, 2024 at 7:26 am #16288868
Vladimir
Hey the memory size is increased, you can check now.
October 15, 2024 at 10:06 am #16289865
I'm still getting the same error. Could you share this debug log file to your hosting provider? They should know what's going on.
October 15, 2024 at 1:26 pm #16291039
Vladimir
It works on our side,it's hosted on our server, I installed plugin to check the memory limit, and it's set to 1024MB, and the site is trying to allocate 200mbs, so this should be working, It works on our side, can you please try again.
October 15, 2024 at 3:09 pm #16291564
You fixed the memory issue but the PHP becomes 8.3 again. Could you reduce only the PHP version to 8.1?
October 16, 2024 at 7:22 am #16293531
Vladimir
My apologies, it's changed to 8.1
October 16, 2024 at 7:52 am #16293833
Now I'm getting the memory error again.
16-Oct-2024 07:51:01 UTC] PHP Fatal error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 372736 bytes) in /home/forge/mip.the-northwest.com/public/wp-includes/class-wpdb.php on line 2315
You need to switch to PHP 8.1 and increase the memory limit for this version. The configuration should be separated. If you're still not clear how to do this, maybe you can consult your hosting provider.
October 16, 2024 at 10:11 am #16294704
Vladimir
That's impossible, I can open the page normally, and the memory limit is set to 1024mb and its using the 276mbs, screenshot attached.
