Last updated by Bigul 1 year, 2 months ago.
Assisted by: Bigul.
December 6, 2024 at 11:53 am #16485924
philippF-8
Dear Bigul,
So far we know that the problem happens only with a certain type of fields (relationship fields with multiple selections)
Your example didn't use an elementor post template as in our case, so it is of limited use but I've managed to setup a new elementor template and new pods with multi-selection fields and it seems to work in different languages:
EN: hidden link
DE: hidden link
The solution was not to use elementor post meta widget but directly add pods shortcode to a simple text or html field (no php insert required).
However, I cannot replicate this success on the actual Elpeguard product groups. The field settings for the relationship fields are the same as in the successful test pods, so it must have something to do with the WPML settings.
Please have a look and if you can, let me know why this works for the "Aa" CPT and not for the "ELPEGUARD" CPT. The WPML account is still open on this test site and a backup has been made.
Philipp
December 6, 2024 at 12:15 pm #16485981
Bigul
Hi Philipp,
It looks like the issue is happening because of the compatibility conflict with the Elementor *Post Info* widget.
Therefore one request. Can you please reproduce the issue in the sandbox site with the Elementor template? I have installed the Elementor plugin on this site now. It will help to escalate this case directly to our developers. Thank you for your kind understanding.
Bigul
December 13, 2024 at 4:38 am #16509864
philippF-8
Hi Bigul,
I lost track a bit because this issue has been split off into several other threads. I think this is being worked on in another thread. If the history of my issue is clear to your team, this thread can be closed.
Philipp
December 13, 2024 at 8:28 am #16510371
Bigul
Hi Philipp,
Thank you for the feedback. I will consult about this with our compatibility team and get back to you as soon as possible on the original thread. Please wait.
Bigul
The topic ‘[Closed] Pods fields are not showing translation when using the Elementor *Post Info* widget’ is closed to new replies.
