Last updated by romainC-25 1 year, 8 months ago.
Assisted by: Osama Mersal.
January 7, 2023 at 6:46 pm #12769187 | |
romainC-25 |
I'm trying to create popups in my menu bar. I follow these 2 docs : - hidden link I assign my defferent popups in the menu setting in fr (e.g. "Contact") then in en (e.g. "New contact us)". hidden link |
January 9, 2023 at 7:30 am #12773315 | |
Osama Mersal Supporter
Languages: English (English ) Arabic (العربية ) Timezone: Africa/Cairo (GMT+03:00) |
Hi, Thanks for contacting WPML forums support. I'll be glad to help you today. Could you please login to this sandbox site and install the popup builder plugin? (hidden link) After that, please try to replicate the issue. If the issue is replicable, please let me know how to reproduce it to check it and consult our compatibility team. Best regards, |
January 9, 2023 at 9:37 am #12774841 | |
romainC-25 |
Hello, |
January 9, 2023 at 9:48 am #12774971 | |
Hi, Thanks for your update. I noticed that the "popupbuilder" post type is set to "Not Translatable" on the sandbox site. Would you please go to WPML-> Settings-> Post Type Translation section on your site and set the "popupbuilder" to not translatable? After that, please check if the issue persists. Kindly let me know the results of the above steps. Best regards, |
January 9, 2023 at 9:59 am #12775005 | |
romainC-25 |
I set the "popupbuilder" to not translatable, but it steel not fix the issue... |
January 9, 2023 at 10:03 am #12775023 | |
Hi, I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP) Your next answer will be private, which means only you and I can access it. ❌ Please backup your database and website ❌ ✙ I would need your permission to de-activate and re-activate the Plugins and the Theme and change configurations on the site. This is also a reason the backup is critical. ✙ I also need your permission to take a local copy of your site to debug the issue without affecting your live site. Best regards, |
January 9, 2023 at 10:56 am #12775825 | |
Hi, Thanks for the access details. I've set the popup post type to translatable and translated it manually. Could you please check the English menu and let me know if the popup works correctly? Kindly check this guide about manual translation. (https://wpml.org/documentation/translating-your-contents/using-different-translation-editors-for-different-pages/) Best regards, |
January 9, 2023 at 11:00 am #12775897 | |
romainC-25 |
I notice that when I change the set of "popupbuilder" to translatable, a message in red appears at the same location and says that the slugs are defined to be translated, but their translations are missing. |
January 9, 2023 at 11:07 am #12775995 | |
Hi, 1) Could you please let me know if the English popup works correctly on the front end? 2) I don't think you need to translate the popup post type slug. Thanks, |
January 9, 2023 at 11:17 am #12776055 | |
romainC-25 |
Thanks for the help it seems to work, but I can't change the default language of the backend, you change it in english and wpml says that the default language is in french ?? |
January 9, 2023 at 11:20 am #12776063 | |
Hi, I changed the dashboard language to site default. Please let me know if it works correctly. Have a great day! Best regards, |
January 9, 2023 at 11:42 am #12776445 | |
romainC-25 |
Yes !! it's working like a charm !! |
