Problem: If you add store credits with Smart Coupons, they are not detracted from the checkout
Solution: we (WPML team) found that to make smart coupons working 100% with our plugin would require big changes in WooCommerce Multilingual plugin (it is our plugin) and for the time being we cannot dedicate time to do this or even triage it to know if this is doable without breaking compatibility with other plugins. Therefore we (again, WPML team, not Smart Coupons team) decided to not continue. Therefore, we can't offer a solution for the issue.
No supporters are available to work today on this forum. Feel free to create tickets and we will handle it as soon as we are online. Thank you for your understanding.
This topic contains 13 replies, has 3 voices.
Last updated by Konrad Karpieszuk 4 years, 8 months ago.
Assisted by: Laura.
January 20, 2020 at 9:53 am #5321979 | |
jeppeK |
If you add store credits with Smart Coupons, they are not detracted from the checkout |
January 20, 2020 at 11:47 am #5322973 | |
jeppeK |
Hello again, I've now set up WooCommerce with a test product, installed Smart Coupons and a Quickpay demo. As you can see on the attached screenshots the issue persists.. If multilingual is disabled it works. This is not only an issue with quickpay but other payment gateways like mobilepay etc. |
January 20, 2020 at 2:08 pm #5324305 | |
jeppeK |
Hi Laura, Any news regarding this issue? 🙂 |
January 20, 2020 at 4:25 pm #5325843 | |
Laura Supporter
Languages: English (English ) Italian (Italiano ) Timezone: Europe/Rome (GMT+02:00) |
Hi, the issue doesn't seem to be with Smart Coupon, but with Quick Pay too. If Quick Pay is disabled, it works fine. As I can see the issue in the Sandbox, I can escalate the issue to the 2nd tier. |
January 21, 2020 at 7:20 am #5329701 | |
jeppeK |
Hi Laura, Thanks for the reply. 🙂 You may very well escalate the issue to the 2nd tier |
January 21, 2020 at 5:06 pm #5335085 | |
Laura Supporter
Hi, in the Sandbox the issue was solved in this way: Can you please check and see if it works for you too? |
January 22, 2020 at 9:14 am #5338885 | |
jeppeK |
Hi Laura, The website where the error occurs already has the WPML's language URL format set to directories and permalinks set to postname. I've also tried it in the sandbox environment and it didn't work? Could you send me screenshots of the settings? Maybe I got something wrong. Thanks in advance 🙂 |
January 23, 2020 at 8:40 am #5346315 | |
Laura Supporter
Hi, I tested again in the Sandbox and it's working for me. Maybe I'm missing some steps to recreate the issue? Could you please send a video where you test in the Sandbox? You can see the settings in Settings > Permalinks |
January 23, 2020 at 10:18 am #5347153 | |
jeppeK |
Hi Laura, Here's a video. I haven't changed any settings. hidden link As you can see you still have to pay 600 DKK when checking out and not 300 DKK. That is the issue. It works if WPML Multilingual CMS or any related plugin (ie. String Translation or Translation Management) is disabled. |
January 23, 2020 at 3:02 pm #5350725 | |
Laura Supporter
Hi, I tested again, and indeed I can see the issue if I use the coupon 36RHDK2Z, but I can't if I try with a new, different coupon (8EPFZ375) that I created for testing. Can you try that as well while we're trying to understand what could be causing the problem? |
January 24, 2020 at 7:55 am #5354889 | |
jeppeK |
Hi Laura, Yes it works, but that is because the coupon type isn't set to "Store credit / gift certificate" but set to "Fixed cart discount". Our clients entire setup uses Store credit for their giftcards 🙂 Thanks |
January 24, 2020 at 11:38 am #5356487 | |
Laura Supporter
Hi, thanks for the clarification. We'll continue debugging. |
January 27, 2020 at 2:44 pm #5370629 | |
Laura Supporter
Hi, I tested with a new coupon as you suggested and I could reproduce as you said. However, it seems that Smart Coupon has other issues with non-standard payment methods (gateways etc) plus other problems with WPML. Our compatibility team worked with the author for a while, but in the end they decided not to continue. Therefore, we can't offer a solution for the issue you reported as we won't make Smart Coupon WPML compatible. We have another coupon plugin that is tested as WPML compatible: https://wpml.org/plugin/woocommerce-extended-coupon-features-pro/ I'm sorry if this isn't the solution you hoped for, but that's the only one I can offer. |
February 3, 2020 at 10:33 am #5411173 | |
Konrad Karpieszuk Supporter Languages: English (English ) Timezone: Europe/Rome (GMT+02:00) |
hi there, I want to clarify the last comment: we (WPML team) found that to make smart coupons working 100% with our plugin would require big changes in WooCommerce Multilingual plugin (it is our plugin) and for the time being we cannot dedicate time to do this or even triage it to know if this is doable without breaking compatibility with other plugins. Therefore we (again, WPML team, not Smart Coupons team) decided to not continue. I am explaining this per Smart Coupon team request as the previous comment could be understood differently. |
