Our wait time is higher than usual, please make sure you are meeting the minimum requirement - https://wpml.org/home/minimum-requirements before you report issues, and if you can take a look at current Known Issues - https://wpml.org/known-issues/. Thank you.
Last updated by Bigul 6 days, 18 hours ago.
Assisted by: Bigul.
March 31, 2025 at 3:36 pm
tudoracheE
I am trying to switch languages on my website, specifically between English and Romanian. We have encountered a problem with the products in the cart not being saved when the language is changed. Previously, this switch worked without issues. The problem can be seen on this page: hidden link.
When changing the language, products in the cart are removed. Specifically, the message 'Ulei de masaj cu extract de banana 150ml has been removed from your cart because it can no longer be purchased. Please contact us if you need assistance.' appears.
Why are products being removed from the cart when changing languages?
How can I ensure products remain in the cart after switching languages?
March 31, 2025 at 3:57 pm
March 31, 2025 at 4:01 pm #16880298
Bigul
Please try the following steps after a full site backup {mandatory} and make sure the bug exists or not.
1) Upgrade to the latest version of WordPress (6.7.2)
2) Upgrade to the latest version of plugins
3) Upgrade to the latest version of your theme (Impreza 8.34.1)
4) Increase the *MaxInputVars* of PHP settings to *10000*. Please check the following article for more details or contact your system admin/hosting provider for this purpose.
5) Clear all types of caches
6) Visit Settings>>Permalinks and resave the settings
Bigul
April 1, 2025 at 10:52 am #16882472
tudoracheE
1. done
2. done
3. done
4. done
5. don't have cache
6. done
result = not work.
April 1, 2025 at 1:35 pm #16883102
Bigul
Thank you for the updates. Please try the WPML and then the WooCommerce Multilingual troubleshooting steps after a full site backup {mandatory} and make sure the bug exists or not.
WPML Troubleshooting Instructions - https://wpml.org/documentation/support/wpml-troubleshooting-options/#troubleshooting-wpml
WooCommerce Multilingual Troubleshooting Instructions - https://wpml.org/documentation/support/wpml-troubleshooting-options/#troubleshooting-woocommerce-multilingual-and-multicurrency
Do you have a staging/dev site (a clone copy of the live site)? Because it will help us troubleshoot the bug without affecting the live site.
Bigul
April 1, 2025 at 2:28 pm #16883485
tudoracheE
I followed those reset options, etc. but nothing..
I made a backup and saved it locally. For duplication, can you do it?
April 2, 2025 at 9:09 am #16886015
Bigul
Thank you for the updates. Please allow me to make a copy of your site using the Duplicator plugin (https://wordpress.org/plugins/duplicator/) for debugging the issue on my local server. So we can troubleshoot the issue without affecting your live site.
Bigul
April 2, 2025 at 9:16 am #16886073
tudoracheE
yes, it's okay.
April 3, 2025 at 7:05 am #16890083
Bigul
Thank you for the permission. But I am not able to access the site backend now. It shows the following warning. The result is the same after several tries from different systems and browsers.
Regret, nu ai voie să accesezi această pagină.
Have you made any changes in the User settings? Please check.
Bigul
