If you're experiencing a 404 error when clicking on the translated version of a page or post, it might be due to a conflict with your custom permalink structure. Specifically, if your structure includes
/index.php/%year%/%monthnum%/%day%/%postname%/
, this could be the root of the issue as WordPress does not fully support such structures.
We recommend switching to one of the default permalink options under Settings >> Permalinks, such as "Day and name". After switching, make sure to resave the permalink settings. This adjustment has resolved similar issues in the past and should help in accessing the translated versions of your pages and posts without encountering a 404 error.
If this solution does not resolve your issue or seems irrelevant due to being outdated or not applicable to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If problems persist, please open a new support ticket.
This topic contains 5 replies, has 1 voice.
Last updated by Bigul 1 month, 4 weeks ago.
Assisted by: Bigul.
May 31, 2025 at 8:59 am #17093855
mohamedI-17
I am trying to use WPML to translate pages or posts on my site hidden link.
When I try to click the translated version of a page or post, it displays error 404.
Why does the translated version of my page or post display a 404 error?
May 31, 2025 at 9:01 am #17093870
mohamedI-17
so the WPML is not working it displays error 404
May 31, 2025 at 5:33 pm #17094576
Bigul
WPML Supporter since 01/2013
We hope you're using the WPML Translation Editor to translate your posts and pages.
Could you please confirm if you can access WPML >> Translation Management and translate content as outlined in the documentation below?
https://wpml.org/documentation/translating-your-contents/#using-wpmls-translation-management
For a better understanding of the issue, it would be very helpful if you could share a screencast (a screen recording showing the steps to reproduce the bug). You can share it via Google Drive or Dropbox. We look forward to your update.
Bigul
June 1, 2025 at 8:02 am #17095034
mohamedI-17
Your support is not adding any positive step to our problem we are still facing the issue
June 1, 2025 at 11:54 am #17095343
Bigul
Thank you for the updates. This sounds like a compatibility conflict.
Please fill in the private details fields including FTP credentials after a full site backup. I would like to access the admin area of your site for further checking. Refer to the following links for more details about our private information sharing policies.
Bigul
June 2, 2025 at 4:36 pm #17098775
Bigul
Thank you for the updates. You are seeing a 404 error on Somali posts and pages due to a conflict with the following custom permalink structure, which includes */index.php/*:
This structure is typically used only when the server doesn’t support pretty permalinks. WordPress does not fully support such structures, which is likely causing the issue.
I was able to get the expected results by switching to one of the default permalink options under Settings >> Permalinks, such as "Day and name". It also works when switching back to your custom structure and resaving the permalink settings.
Please check the site now and let us know your feedback. Refer to this screencast for more details: hidden link
Bigul
