Last updated by denisR-17 1 year, 11 months ago.
Assisted by: Nicolas V..
May 23, 2023 at 10:07 am #13696781 | |
denisR-17 |
We have a problem with JetSmartFiltres translation. After translating the filters according to the instructions, the filters display correctly on the frontend but don't work properly. Could the problem be that not all Travel Planners are translated? The client wants only those who can speak Italian to show up on the Italian site, so only those have been translated. There is also a problem with the 'Select Filter'. The placeholder and Custom Fields have not been translated. You can check it here: hidden link I follow this instruction: https://wpml.org/errata/jetsmartfilters-smart-filters-custom-fields-are-not-translated-in-secondary-languages/ The site is now in the maintenance mode so I can provide temporary access to solve the problem. |
May 23, 2023 at 3:35 pm #13701211 | |
Nicolas V. Supporter
Languages: English (English ) French (Français ) Timezone: America/Lima (GMT-05:00) |
Hello, Welcome to the WPML support forum. My name is Nicolas and I will be happy to help you today. Yes, I'd like to request a temporary admin access (wp-admin) – preferably to a test site where the issue has been replicated – so I can further investigate. Because right now I can't access any of the links you shared but also I think I'll need to have a look at the backend to see how those filters are created and translated. I will activate a private field for your next answer where you can provide that information safely (this field is only visible by you and the support team). Don't share your own admin account, create a new one that you will delete when we finish troubleshooting. IMPORTANT: Before we proceed, please backup your site and database. Also, please add the name of the filter I should work on, for example the one used for Travel Planners. Thanks, |
May 25, 2023 at 1:57 pm #13716971 | |
Hello, I'm not sure to fully understand the issue. So if I missed something please let me know: 1. I was following their documentation here: hidden link But I couldn't see the secondary language column in "Smart filters" to be able to translate them. At the top of the screen there was a button "Switch to classic view". I clicked on it and now I can translate filters (see capture1 & 2). 2. So once I was able to translate (before doing any translation) I went to hidden link But I could see that labels are already translated and also, I did a couple of queries and the filter seems to work well. That's why I'm not sure to understand the issue here. 3. Then I went to hidden link I think that you only need to translate your filters now as I did for "In quanti siete?". Nico |
May 25, 2023 at 2:45 pm #13717381 | |
denisR-17 |
Hello, 1. Filters for Travel Planner was translated in WPML → String Translation. And then I following those steps: https://wpml.org/errata/jetsmartfilters-smart-filters-custom-fields-are-not-translated-in-secondary-languages/ This solved the problem of front-end translation, but on my side the filters are not working properly. Take a look on video that I put on youtube -> hidden link 2. Just a minute ago I translated 3 filters for Boat Charters hidden link and the placeholders have been translated, but text in dropdown was changed from numbers and text to true/false. I would appreciate your help on that cases. |
May 26, 2023 at 12:04 pm #13723011 | |
Hello, Thanks for the video. I'll check those two points now. I'll get back to you with my findings. Nico |
May 26, 2023 at 12:59 pm #13723381 | |
Hello, I think I managed to solve both issues. For the planners, custom fields were set as "Copy once" so they got copied over to italian when you translated them the first time. But we did some changes so I set those 3 fields to "Copy" that way they are copied every time you make an update. Then I updated the translation and it's working fine now. For boats, the issue was different, you are using Filters in Italian and some options that are selected on the English version were not select on the italian filter. Here is the full video: hidden link Nico |
May 29, 2023 at 8:58 am #13730115 | |
denisR-17 |
Hi Nicolas, I just recreate flags on each travel planner listing because they disappeared after fixing the filters but it was just dynamic visibility matter. It seems to work perfect now. I still don't know why the Smart Filters for Boat Charter multiplied itself in italian version - I didn't create second filters for these three 'Select' Filters on Boat Charters. They were probably created after the translation was added the first time in Smart Filter. But anyway... after repeating your steps text on dropdown is still in english. In Custom fields Setting these fields are marked as "Copy"(do-you-need-skipper and rental-period). These four phrases (yes, no, half day, full day) have been translated in WPML -> String translation. |
May 31, 2023 at 11:21 am #13747027 | |
Hello, Let me have a look and I'll get back to you. Please don't make any changes on the site that could affect those filters and pages while I'm working on it. Thanks, |
May 31, 2023 at 12:46 pm #13747647 | |
Hello, I think I found the issue and I'd like to modify the code from the plugin itself. Something similar to the errata you shared but this time in the PHP template for "Select" (instead of "checkboxes-item"). For that I would need to have FTP access or even better an access to a staging copy of your site. I will reactive the private field for your next answer. Thanks, |
May 31, 2023 at 12:52 pm #13747707 | |
Another solution would be to replicate your site on our servers and work on that code safely. For this, I need to temporarily install a plugin called “Duplicator” on your site. Once the problem is resolved I will delete the local site. Let me know if this is ok with you. Nico |
May 31, 2023 at 11:28 pm #13750299 | |
Hello, The code I wanted to test works well on the copy I took. Please create a full backup before you proceed 1. Open the file wp-content\plugins\jet-smart-filters\templates\filters\select.php foreach ( $options as $value => $label ) { 3. Add the following code just after it: //WPML if (class_exists('SitePress')) { $label = apply_filters('wpml_translate_single_string', $label, 'Jet Engine Admin Labels', 'Admin Label - '.$label ); } PS: You can do the same for other type of fields such as radio if needed. Nico |
June 1, 2023 at 8:33 am #13751807 | |
denisR-17 |
Hello Nico, almost perfect. Translation works on two of the three filters. For some reason the filter "How many people are you" has not been translated. To be clear: First, you removed the previous translations that were added to the filters? Because I don't see any more translations previously added in the "Smart Filters". |
June 1, 2023 at 10:47 pm #13758055 | |
Hello, I was able o get the label translation on your production site by adding the "?" (How many people are you?) that way it's exactly the same label in the filter and in the custom field created for your CPT. Filter: hidden link Nico |
June 2, 2023 at 8:33 am #13759313 | |
denisR-17 |
Ok, I see it now. |
