9:00 – 13:00 9:00 – 13:00 9:00 – 13:00 9:00 – 13:00 9:00 – 13:00 - -
14:00 – 18:00 14:00 – 18:00 14:00 – 18:00 14:00 – 18:00 14:00 – 18:00 - -
Supporter timezone: Asia/Jerusalem (GMT+02:00)
Last updated by Itamar 3 months, 3 weeks ago.
Assisted by: Itamar.
July 4, 2024 at 10:25 am
darioB-20
I am trying to switch the languages on my website to English, Spanish, or French. The issue can be seen on this page: hidden link
When I switch the languages, the widget of the product categories doesn't appear, creating an empty section on the page. Normally, I expect to see my product categories translated, but they remain empty.
Why doesn't the widget of the product categories appear when I switch languages?
How can I ensure that my product categories are translated correctly?
July 4, 2024 at 11:14 am
July 4, 2024 at 11:18 am #15891473
Itamar
When you have the staging site ready, please proceed with the following.
I suspect that there is a collision with the theme or another plugin that might cause this problem. If possible, get your site into a minimum environment, Which means switching to a default WordPress theme like TwentyTwenty-One and having no plugins activated except WPML.
First, you must check if the problem persists when just the theme is switched to TwentyTwenty-One (for example). You are using the Hello theme from Elementor so you can stay with this theme. If it persists, deactivate all plugins except the WPML, its add-ons, and Elementor itself (without its extensions). Then please check if the problem persists. If it does not continue, start by activating the plugins individually, check when the problem comes back, and then report which plugin was the culprit.
Itamar.
July 5, 2024 at 9:39 am #15897639
darioB-20
Hi Itamar,
during the day I will create a new test site where I'll follow your suggestion.
I'll backt to you as soon as possible when I tried every step you suggest.
Best Regards,
Nikolas
July 7, 2024 at 7:36 pm #15908122
Itamar
Hi, Nikolas.
I'll wait to hear if you need further help with this issue.
Itamar.
July 8, 2024 at 9:39 am #15911974
darioB-20
Hi Itamar,
so here we are:
- I tried to create a copy of the website and ?'ve done all the purpose that you suggest but without good result.
- I tried to create a new page, with new custom "product category widget" (a little bit different as the one published on the live website) created and published. After that I translated this new page in all the languages, also here the product category widget doesn't appear. Only in italian version is visibile.
Any other suggestion about this issue?
Is really crazy why "only" di widget wouldn't appear in the other languages.
I tried also to create other product widget and they appear, but not the product category.
I've no idea about the reason.
Nikolas
July 9, 2024 at 10:31 am #15919921
Itamar
Hi, Nikolas.
Can you please share access to your staging site with me so I can continue checking things there?
Privacy and Security Policy
**IMPORTANT**
Itamar.
July 11, 2024 at 7:24 am
July 11, 2024 at 4:26 pm #15936557
Itamar
When I try to log in to hidden link with the details you gave me for hidden link, I get this message:
Errore: il nome utente Itamar non è registrato su questo sito. Se non sei sicuro del tuo nome utente, prova invece il tuo indirizzo email.
Please check it and correct it. I'm enabling a private message for the next reply.
Itamar.
The topic ‘[Closed] Problem with widget translation’ is closed to new replies.
