You are trying to translate your site and products using WPML, but the product images are not showing after translation.
First, ensure that the following options are enabled in the WPML Language widget on the right side of the product editing screen in the original language:
- Duplicate uploaded media to translations
- Duplicate featured image to translations
If the images still do not appear in the translations, we recommend trying the workaround suggested in this ticket.
Additionally, go to WPML>>Settings>>Media Translation and ensure that the media duplication settings are enabled to prevent this issue in future translations.
If this solution does not resolve your issue or seems outdated, please check the related known issues at https://wpml.org/known-issues/, verify the version of the permanent fix, and confirm that you have installed the latest versions of themes and plugins. If the problem persists, we highly recommend opening a new support ticket here.
Last updated by 2 months, 3 weeks ago.
Assisted by: Bigul.
