- | 12:00 – 14:00 | 12:00 – 14:00 | 12:00 – 14:00 | 12:00 – 14:00 | 12:00 – 14:00 | - |
- | 17:00 – 21:00 | 17:00 – 21:00 | 17:00 – 21:00 | 17:00 – 21:00 | 17:00 – 21:00 | - |
Supporter timezone: Europe/Vienna (GMT+01:00)
Last updated by Gerard Blanco 6 hours, 8 minutes ago.
Assisted by: Bigul.
February 28, 2025 at 12:20 pm #16760603 | |
Gerard Blanco |
March 2, 2025 at 5:09 pm #16765916 | |
Bigul Supporter
Languages: English (English ) Timezone: Europe/Vienna (GMT+01:00) |
Hello, Welcome to the WPML support forum. I will do my best to help you to resolve the issue. Please try the following steps after a full site backup {mandatory} and check if there is any difference in the result. 1) Upgrade to the latest version of WPML (4.7.1 series). May you have to visit Plugins>>Add New>>Commercial tab and click on the *Check for updates* button to get the WPML automatic upgrade links of the latest version. This step will help us refresh the installer caches. hidden link -- Bigul |
March 3, 2025 at 2:10 pm #16769444 | |
Gerard Blanco |
Hey Bigul, I've done every single step, from 1 to 5, and the issue is still there. What else can we do? |
March 4, 2025 at 7:31 am #16771673 | |
Bigul Supporter
Hello, Thank you for the updates. A couple of requests for tracking this. 1) Please share the URL of the couple or posts/pages having the problem 2) Please fill the private details fields after a full site backup. I would like to access the admin area of your site for further checking. Refer to the following links for more details about our private information sharing policies. hidden link -- Bigul |
March 4, 2025 at 4:26 pm #16775185 | |
Bigul Supporter
Hello, Thank you for the updates. Please check the attached images. Now the Hebrew language is hidden for the visitors. So it will not be available in the frontend. But as an admin user, we can view it by selecting the *Display hidden languages* option of Users>>Profile>>Hidden languages. Also, hidden link is translated. But it is pending for review now. Please publish it and let us know you're getting the expected results or not. Refer to this article for more details - https://wpml.org/documentation/reviewers/how-to-work-as-a-reviewer/#how-to-review-translations -- Bigul |
March 4, 2025 at 5:22 pm #16775348 | |
Gerard Blanco |
Hi Bigul, I think there's some confusion here. I kindly ask you to have a look at this video for a better explanation, it's just 2 minutes and a half: hidden link Thank you! |
March 5, 2025 at 3:52 pm #16779758 | |
Bigul Supporter
Hello, Thank you for the details. I can see the issue now and checking with our team. Just to make sure, you are not switching to the latest version because of the issue, because of the following reason? Please confirm. I switch to the new version of the Advanced Translation Editor, but there Ctrl+Enter does not go to the next line, making it inefficient. -- Bigul |
March 6, 2025 at 5:46 am #16781062 | |
Gerard Blanco |
Hi Bigul, In theory yes, that's the case. However, even if we could translate/review all the fields without having to touch the mouse, I think that my translator wouldn't use the new version because he says it feels more clunky and doesn't really like it 🙁 Thanks, |
March 6, 2025 at 8:26 am #16781713 | |
Bigul Supporter
Hello, Thank you for the updates. I am unsure how much backward compatibility the ATE editor will be able to achieve. Because the latest version includes a lot of improvements in functionality. So one request. Can you please check the issue is reproducible in our sandbox site (a fresh installation, only WPML plugins are active with 2025 theme) - hidden link Login URL:- hidden link It will help us to escalate the ticket directly to our developers. -- Bigul |
March 6, 2025 at 12:50 pm #16783327 | |
Gerard Blanco |
Thanks, Bigul. I'm trying to set up everything but I got stuck. I created a username "translator" with the password "translator", and I even assigned 2000 credits from my account to the site pink-gong.sandbox.otgs.work, but the site is not recognizing the credits, so I can't send any post to be translated: hidden link How do I continue from here? |
March 6, 2025 at 3:06 pm #16784183 | |
Bigul Supporter
Hello, Thank you for the updates. The actual translation credits will not be working in the Sandbox site because of the test environment. But I have connected a Dummy card now for testing (it will be a raw translation). So please try to translate the post now and check if you can reproduce the issue or not. -- Bigul |
March 6, 2025 at 4:15 pm #16784661 | |
Gerard Blanco |
Hey Bigul, Thank you for that. I confirm that I am able to reproduce the issue. With the previous version of the Advanced Translation Editor, the changes I make when I'm reviewing the post are not visible. Even if I publish the post the issue is there. For example: hidden link The title of the post should have a '2222' added at the end, and while it's visible if you edit the translation in the WPML editor, it is not in the published post. I hope that helps 🙂 Thank you. |
