Last updated by Dražen 1 year, 7 months ago.
Assisted by: Dražen.
September 5, 2023 at 2:51 am #14339589
Kulatuch Suwattanapunkul
When changing default language from English to Thai, there is no change in site language of the entire site shown on wordpress Settings page
Tried many forums on wpml website, not successful
September 5, 2023 at 6:47 am #14340123
Dražen
thanks for contacting us and reporting this.
This small cosmetic glitch has already been reported to our team, and we are looking into it.
I will update you when there is more news or fix is released.
Note this does not cause any issue other then cosmetic/visual differences.
Drazen
September 5, 2023 at 7:45 am #14340483
Dražen
this issue has been escalated to our devs team and will be fixed in one of the next versions.
In the meantime you can use the next workaround:
in \wp-content\plugins\sitepress-multilingual-cms\classes\utilities\class-wpml-locale.php change public function locale() method to:
public function locale() {
		//if ( ! $this->locale_cache ) {
			add_filter( 'language_attributes', array( $this, '_language_attributes' ) );
			$wp_api  = $this->sitepress->get_wp_api();
			$is_ajax = $wp_api->is_ajax();
			if ( $is_ajax && isset( $_REQUEST['action'], $_REQUEST['lang'] ) ) {
				$locale_lang_code = $_REQUEST['lang'];
			} elseif ( $wp_api->is_admin()
					   && ( ! $is_ajax
							|| $this->sitepress->check_if_admin_action_from_referer() )
				$locale_lang_code = $this->sitepress->user_lang_by_authcookie();
				$debug = debug_backtrace();
				foreach ($debug as $frame){
					if($frame["function"] == "get_locale" && str_ends_with($frame["file"],"options-general.php")) {
						$locale_lang_code = apply_filters('wpml_default_language', NULL );
			} else {
				$locale_lang_code = $this->sitepress->get_current_language();
			$locale = $this->get_locale( $locale_lang_code );
			if ( did_action( 'plugins_loaded' ) ) {
				$this->locale_cache = $locale;
			return $locale;
		return $this->locale_cache;
Drazen
