Last updated by Bobby 1 year, 10 months ago.
July 7, 2023 at 8:31 am #13965923
daniel-viktorV
Thank you, I will report this to the developer of Greenshift!
Meanwhile, I've run into another problem:
As you can see from the links I've already posted, the menu is structured to be accessed from a hamburger menu (also on desktop). This is implemented with the 'traditional' navigation block. However, when I try to translate the navigation items (using the FSE template translation description), WPML simply does not recognize the menu items (neither the titles nor the links).
What could be the problem here?
July 8, 2023 at 12:04 am #13970613
Bobby
WPML Supporter since 04/2015
While waiting for one of my colleagues to help you, please review the following documentation on how to add a menu translation:
https://wpml.org/documentation/getting-started-guide/translating-menus/
when following the steps from the documentation are you able to resolve the issue?
if not, please share with us some screenshots from the backend if possible to help better understand what might be causing this behavior
The topic ‘[Closed] Split: Greenshift not showing Navigation block in Translation Editor’ is closed to new replies.
