This topic is split from https://wpml.org/forums/topic/elementor-pro-text-not-translated-but-not-showing-on-the-front-end/
Last updated by calypsoP 1 year, 7 months ago.
June 13, 2023 at 1:45 pm #13817739 | |
calypsoP |
Hi there, Thank you for resolving my previous issue. However, I encountered another problem with the footer. The phone number was not detected by the Advanced Translation Editor; only the link was recognized, but not the digits themselves. Additionally, when I input numbers, they appear in Arabic instead of Hindi, the desired language. To work around this, I have been sending myself a WhatsApp message in Arabic with Hindi digits and then copying and pasting it into the Advanced Translation Editor. However, this is not a sustainable solution. Is there a more effective approach to addressing this issue? You can find the Footer under WP Dashboard > Templates > Saved Templates > Filter (all) > Footer. |
June 13, 2023 at 1:56 pm #13817875 | |
Christopher Amirian Supporter
Languages: English (English ) Timezone: Asia/Yerevan (GMT+04:00) |
Hi there, To show the numbers in Advanced Translation Editor you need to search for it at the top left search box. For more information: I searched for it and added Arabic numbers. (check the screenshot) Please change it according to your needs. Thanks. |
June 13, 2023 at 8:12 pm #13820131 | |
calypsoP |
Hi there, Thank you for your help. How did you write in Hindi numerals? |
June 14, 2023 at 7:55 am #13822447 | |
Hi there, If you have the Arabic language added to your machine, when you switch the language you will have those numbers when you type them. I have Persian language on my device and it has the same number methods. Alternatively you can copy/paste the numbers here: ٠ ١ ٢ ٣ ٤ ٥ ٦ ٧ ٨ ٩ Thanks. |
June 14, 2023 at 1:19 pm #13825489 | |
calypsoP |
Hi there, Thank you again for your reply. I have the Arabic language on my machine with Hindi numbers. If I type in Word, Notepad, or even the calculator on my Windows machine, they all type in Hindi numbers. Even when I type numbers in any of these apps and then paste them in the WPML Advanced translation, it changes to Arabic numerals. I recorded the above in a video: hidden link |
June 15, 2023 at 5:49 am #13829089 | |
Hi there, Thank you for the video. The issue that you are experiencing is related to your machine as I do not have that issue. I explained it here: hidden link Thanks. |
