Last updated by timK-2 1 year, 9 months ago.
Assisted by: Long Nguyen.
May 6, 2023 at 7:02 am #13597593
timK-2
Thank you, Long!
I'm going through all the steps atm; however, I am facing another problem now.
I cannot update the plugins because of this error " You are using an unregistered version of WPML and are not receiving compatibility and security updates. Register now"
The version is registered; I had this error a few times before. It usually disappears after a few days, and everything returns to normal. How can we solve this problem?
Tim
May 6, 2023 at 7:07 am #13597595
Long Nguyen
Hi Tim,
Thank you for your feedback.
Checking on our server, I see the registered domain is hidden link while your current domain is hidden link. With www, it is a different domain and WPML will consider it as an unregistered version.
You need to re-register your site with a new domain to fix the issue, please follow this documentation https://wpml.org/faq/install-wpml/#register
Look forward to your reply.
